NTU ppl lip lai! - Part 1
Junior87
For the degree programme, advanced topics in C / C++ and Java (i.e. network / socket programming, multi-threading, etc.). Also, SQL for the third year course on databases. There's also Ada for a fourth year course.
For FYP, some projects may require MATLAB, C#, or other .net programming languages (mine was in C last time, but that's because I did programming from the application space all the way down to the Linux kernel level).
If you intend to further your studies, Python and shell scripting will come in useful too.
also.. if you're doing the software engine proj for ce.. there's mysql, apache tomcat, scripting, xml maniupulation, and open gl or unreal 3d or whatever 3d api you use..
lonestar86
RESULTS LEAK LIAO!!
i mean my IPPT results!! :s13:
:o
abduls85
wao huai nid sho long?
The most logical reason that i can think of is that maybe they need to wait for the students doing EIA ( 30 weeks ) so that they can moderate the grades together. That might be the reason for the delay.
Junior87
Me year 2 only... Still got more good years to go... Just wondering what language is good to learn and useful for internship and future jobs...
depends on which industry ure looking to work in..
LotusSoup
btw dean list for NTU izzit based on 2 successive sems or izzit based on your academic year 1,2,3 and 4?
Caulibeam
i think is per year. :o else those who never get for first year probably have no chance of getting it at all
LotusSoup
oh let me clarify. so it means it is based on results like yr 1 sem 1 and yr 1 sem 2. if u get more than 4.5 for yr 1 sem 2 and yr 2 sem 1 it is not counted?
Junior87
yes its over 1 academic year..
no you dont get dean's list for going over 4.5 alone.
terabytez
principle of genetics who take be4?
BS107? i took before. I took it as a UE last last sem. No midterm. No lab to help you so it's 100% exam for you. Biology core students get 30% from their lab work. The exam format I had was 100% multiple answer MCQ (50 Qns), meaning there may be more than 1 correct answer and you have to choose ALL correct answers in order to score the point. No separate bell curve for UE students. As with all other biology modules, lots of memory work required.
Danger21
wow... but the modules they teach like quite easy~
