Google Nexus S
sianz
Vulpix, is there a way to test battery drain to make sure the phone battery is not leaking?
divingwithme
Battery life will depend on how crappy your area's signal is. If you're living near a tower, then your battery life confirm very good. However if you are like me and living in the west or east, gg and lol at your battery life.
yes stay near tower help you means good reception. but if u stay far and above 12 floor u can get worst reception.
Vulpix
Moderator
Moderator
Huh? If your phone never explode while charging most likely your battery not leaking?
HMAN
Click the battery use then click on the battery chart on top of screen. Yottu can see how. Fast battery drain out.today with sync on, get 30 hours @ 15% battery level.
Look like cloud to phone service drain battery
TuckyLee
Hi there, do you know where to get the Nexus S screen protector and handphone casing? Mine is peeling off real soon.=(
sianz
Something must be wrong with my phone..I only get about 16+ hours...do you use your phone heavily HMAN?
sTiCkY
anyone play this game called alchemy on ur phone anot? LOL!!! damn addictive..
agcken12
backup app, play wirh different rom and customisation and over clock or under clock also.
HMAN
oh so you plug it into a car dock? That means you charge it while in the car?
Typo error..thanks to the gingerbread keyboard..i am suppose to say "Voice Call" .
I think the best time to trace what app hogging phone and force it to stay awake..is monitor the consumption rate on long standby time like before you sleep..
Anyone manage to get market update ?
