DELL STREAK USERS COME IN !!!
p9844131
But Dell USA do not accept Singapore Credit cards. Neither does Vpost, Comgateway and Borderlinx conceirge services works. U got it via USA Dell? Could u advise how u go about getting one?
chng238
I don't own the Dell streak....I was choosing streak or venue....
My venue coming from HK next week........
marcusshei
how I can i change my dell streak theme.. just bought it and i want to change the theme.. tnx!!
Poh
Anyone have our original baseband amss.abn file? I flashed mine and would like to restore it back?. thanks.
norteklaser
hi every1. im a new dell streak user. just have some question:
why cant i download movies using the browser?
what browser and site you tried?
some of my browsers can some cannot. also streaming sites like mysoju cannot but mediafire can.
lockks
Got a few grumbles...
The call volume is also very low even at full volume. Same for music listening. Any Solutions?
And the bluetooth in dell steak doesn't detect my bluetooth adapter...dun kow why...
diu___
Where can get Dell Streak without contract other than whymobile?
from Starhub no contract how much?
If order online from dell or other websites, delivery time roughly how long?
Thanks!! : )
Really wan to get my hands on it, but also heard starhub 3g not v good.. how??
i wanna know alos
starhub no contract how much?
pikmin23
Hi ppl, I am wondering if it is too big for a phone. Ie will it be very troublesome when you use it to make a quick call? It seems that 4.3' is probably the furtherest you can stretch the screen
diu___
where to buy streak accessories like car cradle kit, sextra use cable ?
norteklaser
responsiveness
How about typing sms'es is the keyboard as responsive as say iphone? For the iphone the keyboard response pretty good which enables me to type lightning fast (much faster than typing on bb!)?
Btw I always wonder how some ppl can reply thread so fast one huh...
In general, no. Sometimes, when I want to click on a "mark as favorites" star sign, I have to click 3 or 4 times before it lights up. Transferring icons from one home page to another is also not so easy and sometimes the app opens up instead of moving to the next page, and sometimes when i want to type i, the o shows up instead etc.
iphone in contrast, is much better. but if you want to do a lot of typing, nothing beats good ol blackberry. i've used all 3 before, so all these from personal experience...
norteklaser
For me it's ok. but i let some ladies try, they find it hard. think 5" is max for me to comfortably use as a phone and put in my pocket, but if you are a lady, then iphone would be better in terms of size.
norteklaser
Use superoneclick
Thanks. just tried again today using version 1.6.5. no luck even removed sd card, switched on debugging, switched off and on again during rooting, tampering with debugging switch, installing adb, drivers from dell etc. sienz.
benny888
Can your phone be detected by the PC ? Do not assume it is. Check this by :
Put your Streak into Fastboot mode by powering on while holding the camera button. It will show a screen that says ‘Touch Calibration’ and ‘Fastboot’. Tap Fastboot. You will now see ‘Wait for USB FastBoot detect….’. Connect your phone to computer using the USB cable. The screen should display ‘FASTBOOT_MODE’.
If the phone screen is stuck at ” Wait for fastboot…” : then try this – On computer, Go to Device Manager. You should see an errored item called Android 1.0. Right click Android 1.0, select Update Driver Software, select Browse my computer, select Let me pick, select All Hardware, scroll down to Android Phone , select Android Bootloader and click OK.
If above fail then you need to reinstall drivers:
Download the correct drivers
Android SDK : http://developer.android.com/sdk/index.html
Windows drivers from here: ( or google for the exe file )
ftp://ftp.dell.com/Handheld/R288920.exe
Dell Mobile sync software if you need it for syncing :
http://www.nero.com/link.php?gen_id=10&to=9999&installmd5=mhubdell&prg=installmhubdell-1.exe
norteklaser
how much is the toa payoh one? and how much from overseas?
Cable is 39 from singapore but 26 pounds from uk. Shipping another few bucks. The silicon casing and screen quite cheap from overseas (less than 20 sgd I think) so I didn't bother to check out the singapore shop price.
