Google Nexus S
Beta_Tester
gt omr google update.. u all root it then install or b4 that install or it doesnt matter?
smallobjects
NEXUS S charging
wat software u use to root?
i feel charging the nexus S takes forever, like 2hrs charge for 50% charge. uSES nokia n97 org charger, shorten charging time by 30-40%.
anyone can share?
sacredrays
hi guys,
May i know if google nexus s have international warranty?
Seems to me like everyone got the phone from US and i was wondering if there is warranty support for nexus s in singapore....
Thanks!
davidquah
anyone can share?
i am using usb wall plug. faster but i haven't really timed it.
davidquah
anyone having problem with apndroid ?
sometimes no connection until i rekey password and reboot.
klanse
anyone can share?
Are you comparing original charger with nokia one? Original charger got only .7amp so I guess nokia has higher amp?? Get a Griffin power block or an ipad charger, which has 2amp. It does shorten my charging time :)
HMAN
The phone charging circuit read the pull up resistor value to see genuine charger is used, if found no trace of it, the circuit will assume standard USB which has spec limit of 500mA .
In summary, you won't be to enjoy with higher current rate unless you know what logic the circuit deployed, even you find the logic but without understand the thermal management design, you still ended
killing the phone.
Need hero to run the experiments!
Vulpix
Moderator
Moderator
Sigh, my phone doesn't like being overclocked. Won't even go to 1.2ghz. :(
Vulpix
Moderator
Moderator
Yeah amazingly it shortens the charging time on my iPad as well, but it doesn't shorten the time for my Nexus S charging.
smallobjects
Yes compare differences in org. Nexus Usb adaptor and my nokia n97 org. Charger. N97 is 1.44mah while nexus 0.7mah. Nexus adaptor takes forever to charge. N97 org. Charger. Half d charging time. Looking at even higher current adaptor?.
Anyone can share? Better like 2.5 or 3.0mah.. best.
