Google Nexus S
bryant_16
Check under m1 homepage under coming soon phones. Incredible S and Optimus 2x are the 3 phones that they are launching.
JJJ010101
eheh... i still thinking when should I root and go CM7.. how's the batt life for CM7 compared to stock GB? also, which kernel you guys use/suggest?
Vulpix
Moderator
Moderator
CM7 + Netarchy 1.2.4 + screen off 100-400 profile = XTREME battery life
JJJ010101
need some help here on rooting.. I can't get past the fastboot mode =/
my adb was working alright. But when I'm in fastboot mode and type "fastboot devices", my device is not detected. Hence my "fastboot oem unlock" will not trigger (stuck at waiting for device)
is it the fastboot drivers? which are the fastboot drivers or how do I get them? can't seem to find anywhere.. did googling and some said to install pdanet some said it's not required. i'm lost..hahaha.
Vulpix
Moderator
Moderator
If it's not working, install the pdanet drivers. If it is, then no need. That's how it is.
JJJ010101
sry I forgot to mention that I tried installing pdanet and It still didn't work.. are fastboot drivers and pdanet drivers the same thing? I still can't get pass fastboot mode
haocan
wanna check if anyone still stuck with 2.3.2?
cause apparently my nexus s didn't receive the update alert.
tishfire
Ur purpose is to root right? I'm not sure about this, but can u use "superoneclick" to root? It is really 1 click and ur device will be rooted and they even install busybox for u
JJJ010101
I did it! thanks! kept trying and searched around for solutions :D *hurry off to flash rom now...*
