Google Nexus S
Red_Cheesepie
Official Android 2.3.3 updates for Nexus One and Nexus S unearthed, available to the impatient
Waiting sucks, doesn't it? Yes, yes it does -- which is why we're delighted to see that direct links to the official, final updates to Android 2.3.3 for the Nexus One and Nexus S have both been turned loose. This is especially exciting news for Nexus One owners who've stayed on the straight and narrow and haven't moved to a cooked Gingerbread ROM already, since they're still on Froyo -- but it's also good news for developers working on NFC apps with the Nexus S and Android's freshly-baked NFC API, since it means they'll have real-world devices to start playing with. So go on, get to it -- we know you're not going to wait for the over-the-air notification anyway.
Source: http://www.engadget.com/2011/02/24/official-android-2-3-3-updates-for-nexus-one-and-nexus-s-unearth/
Can get zip file from http://forum.xda-developers.com/showthread.php?t=965478
WAHAHAHA 2.3.3
HMAN
Direct google OTA link for Android 2.3.2 to 2.3.3
http://android.clients.google.com/p...9e.signed-soju-GRI40-from-GRH78C.98f3836c.zip
I have yet to apply this update with standard recovery->apply update.zip method
What holding me back...2.3.3 disabled "fastboot boot " command on locked bootloader..
I find fastboot boot is a god send command that allow trying out of new recovery image by injecting the contents into RAM and run from there..which is very safe to try new recovery..while retaining existing recovery.
You may try the following sequence to keep the root and maintain locked bootloader..
From Android 2.3.2 /rooted/locked bootloader
1) Fastboot boot recovery.img..to boot into recovery CW recovery screen
2) Apply 2.3.3 update.zip ..
=>Do not reboot ,as this 2.3.3 has Bootloader change that disable fastboot boot for locked bootloader.
3) Without rebooting , mount system, apply su.zip
4) Reboot..
HMAN
I used the method below..root retained....no need to unlock bootloader..
After update..phone run much smoother..scrolling speed is fast..browser is fast..
The color dull people reported is real..however no big deal for me..
I turn on the NFC.put EZLINK card near to my phone..it pick up the card but display Unknown card type..
Code:
I manage to keep the root for 2.3.3 with the flashing sequence listed below.
=>After applying update DO NOT REBOOT ,as this 2.3.3 has Bootloader change that disable fastboot boot for locked bootloader.
=> This step is to reapply Superuser.apk permission setting
4) Reboot..
davidquah
anyone using swype ?
i update my stock 2.3.2 to 2.3.3 and now got the
"configured for another device" message, even after reinstall.
kifo
Updated... new 2.3.3 feels even faster. I feel it needs to slow down a bit. :D
JJJ010101
Can check with Nexus S users that, in 16gb of memory, how much space is for games/apps?
1gb for games/apps, the rest for storage.
I got a dumb qns.. using titanium backup I just have to run "backup all user apps + system data" right? do I have to check any options in settings to make sure the market links are backed up as well?
bryant_16
sorry to check with you again, games like gun bros allow you to download the apk file first then after that download the game data, so in this case, these game data will be in the storage or falls under the 1gb (games/apps)?
kennyboy
In storage....
kennyboy
by default it backs up market links.
kennyboy
so after 2.3.3 the facebook synced photo in contacts are all gone? kinda sucks :(
U can use syncmypix to do the photos, but facebook integration into contacts is bye bye for Nexus S users.... if u update.
kennyboy
ok, thanks.. one more dumb qns, if I flash back to stock rom will my custom kernel revert back to stock kernel as well? if not, how do I get back stock kernel?
Sorry man, u gotta ask a Nexus S user... :D I can only help with what I know. :(
