coyote
- Sep 20, 2000
That is a very valid reason actually. Though I would have expected for such a trial based experiment, TS would not have needed to spend too much on 16G or ram & 6 cores processor. Probably 8G ram & a quad core is more than suffices.
I did VM Ware on my ubuntu running with 2 cores & 2G of ram. I had fedora & windows installed on the server. They all work out fine except for the graphic department, which is much needed on a standalone pc but not possible on the VM environment. So, in the end, I just disassemble them instead of taking up disk space. In ubuntu, my fiend uses virtualbox to do the same, which is pretty easy also, again for experiment purpose.
To learn, to simulate and to integrate IT environments using x86 virtulization![]()
; more CPU cycles consumed when more NICs are placed; which is why Intel NICs or server-grade NICs with CPU Offload, VMDQ etc ...
, bo bian, moi their supporter... *
