Gixxerfied
- May 24, 2008
Thanks again guys for your patience.
With regards to the pictures above, the 1st & 2nd pics refer show the ONT? Or is that the router? Or ONT=router? It has 4 lan ports so it looks like a router to me but only 1 port is used? I am confused.
In the 2nd pic, i see 3 cables - 1 skinny yellow i presume is the fibre wire to TP, then there is a black power cable and a yellow ethernet cable which goes to MioBox in 3rd pic? So what is the MioBox? Is this the miotv settop? Or does it include voice ip and also internet and router will then connect to this miobox?
The 1st 2 pic is the ONT and only Port 1 can be use.
Cant help u on the miobox as i'm using M1..
