ASUS announced U36 model notebook
ehong1805
Went with colleague yesterday and he bought U36 for $1398. Price not drop, but free upgrade to 8gb (2x4gb). The rest standard free gift from asus.
zero_88
I just brought the U36JC
1.Do I need to discharge my laptop battery first b4 I charge?
2.Really need to charge 8 hour?
3.Is it better for me to discharge my battery first b4 I store them?
4.If store them aside for long period of time, i take them out again, do I need to charge 8 hour again?
how to maintain laptop battery?
Pikachu84
Yes first time charge for a long long time!
Refrain from fully discharging, keep it over 15%
Once in a while make sure to charge for long time keep the battery at 100%. I can explain to you why, but only if you understand physics and chemistry.
Only i you feel the computer not showing the correct time left for the battery, you should consider fully discharging. Follow a manual online. Just google it.
nuky8181
lol. Finally got it.
Doing the backup for the recovery disc. It prompted that it need 6dvd!!! Wonder if I saw it correctly........
Anyone going to dump all the software and do a fresh installation? Can advise how to do it?
In the past I just install a "original" OS over it and recover all the drive from the recovery disk.
Think this is rather dumb. Any way to install the original OS into the system without all the other software that come with it? Then from there, selective install stuff that I want.
My feedback on this notebook about some of the comment made previously
Ok, it do feel a bit warm. Especially on the right side. Wonder if the HD is located there. Maybe can replace it with SSD so wont be that warm. The left side could be the CPU. Think can reduce the setting of the CPU to prevent it from being too hot.
About vibration. Can feel it more compare to my dinosaur Lenovo. Oh well, the profile is thinner so I guess bo bian.
Thats all that I can say for now. Still, I like it. haha.....
Oh one more thing, where to get the keypad skin for this? Can share?
zero_88
i want to noe also
MarineX
thanks for the honest feedback.
fortunately i did not recommend this "heater" to my friends.
lippi74
Bashing something that you have not even see or touch????
Maybe your should open your eyes/heart more so that you can make better and more meaningful comments.
nuky8181
Lets ignore such comments.
2nd day trying it out. Everything is alright. Anyone know what is the top right button thing do? I know it is suppose to let me start up fast. Tried it just now, end up at something like a "safe mode" window.
Ya also, any one so steady to format it already and did a fresh installation? Haha..... if no feedback then I wont go do what I usually do. Is going to take too much time to find all driver. :D (hm.... or maybe will do it after my exam. haha.....)
Also, saw this keyboard protector in the market section, that attract less dust and also fend off bacterial. The seller has not feedback leh. Dunno if they have the version for this notebook. Going to bring it around so dun wish to see the key scratches my screen. Now still using it with the plastic that come with it......
MarineX
i have seen touch and feel it. It is GOOD to CONVINCE yourself that it ISNT
please don't make assumptions that i didn't.
even IF i didn't, the reviews surfacing online have said enough. JOKE
MarineX
zero_88
where to get the skin?
nuky8181
don't wish to create havoc here.
thus i am out of here.
Seriously. After posting 3 more post then u say u dun wish to create havoc....:s11: All technology stuff has its pro and con. what you have posted in the last 3 post is rather unfair.
Also, dun you think if your comment was " glad that I have not recommended this notebook due to heat issue" might be a better one and you would not have triggered all these feedback? Try to take a step back and look at things and I believe you will be a more wiser person. Cheers.:D
Yo2020
normally with such a thin casing, CULV CPU will b a better choice for lower heat n lower power consumption. unfortunately, CULV is more expensive.
