Foodelicious!
twtan14
It's not that hard
Here's what I do
500g of pork belly - score the skin with a knife and then rub a little sea salt onto the skin after you paper dry it - the salt will absorb the moisture and make the skin super crispy
Optional whether you want to put 5-spice power on the meat itself - I just went with a little bit of rock salt...
Also optional - stick it into the fridge for a couple of hours to further dry the skin...
Else throw it into a toaster oven - grill for 20 minutes on either side and then finally another 10 minutes just on the top...
And when I took it out of the oven, I can still hear the skin crackling
Paiseh, I did take pictures but don't have them in the office - will repost later when I get home :s13:
You using toaster oven!? My toaster oven cannot adjust the top and bottom heating elements, so will burn the meat every fast one.
carey
Yes, I found that the toaster oven - Cornel - works very well...hahah
I thought you can switch either top, bottom or both on?
twtan14
My lousy oven cannot switch to either one, both will always be on. So very fast chao ta the food.
dennyz
went to ah loon and ah teck to buy some durians for granny and aunty to eat
first pic is D101 aka Red Prawns + D13 mix in a box
2nd and 3rd pics is Black Pearl aka Hei zhen zhu + JinFeng aka Golden Phoenix mix
enjoy!
raven1019
enjoy!
how much damage ??????
Kaki369
Yeah man... Sifu Denny... How much damage? Esp the Black Pearl... OooOooOoo
kunoichi
friends bring the mountain turtle AUNTY go Farmart jiak jiak :)
sambal chilli stingray
kailan with garlic
sambal chilli sotong
kampong chicken with garlic (this one very little meat... feel so cheated!! 他妈的)
BBQ chicken wings
