Use 2wire 2701hgv-e with starhub cable
jlpk007
great post..i am also planning to jump to Starhub and use this 2wire wireless modem as a wireless router for starhub gateway..:)
HoGnix
I am not encourage/discourage people to flash to non-Singtel firmware, flash alwaye involves the risk.
Here I only provide the relavent info and solution for the TS to make use this 2wire modem on non-Singtel line service.
So far I know, only Singtel V6 firmware blocked the WAN connection. Qwest firmware does not. (after flash, you can use WAN, but if you have reset the modem, it does not have option to select the WAN connection again)
adlky
Thanks for your post! I just tried this to connect my 2wire with M1 cable broadband and it works too!!
Saved me some money buying a new wireless router.:)
Does anyone know if the 2wire will work with SIP phone too?
shotz
Hi marineX,
Can the 2wire 2701hgv-e be connected directly to the ONT bypassing the 5012nv ? Just in case 5012nv become faulty.
me noob
sidmania
Awesome post! A borrowed Linksys WRT120N router was trashy for wireless.
Now i have re-used the 2wire from my terminated Singtel acct as a normal routing device. IT has been great when i was on Singnet.
tan1cs
I'm trying to use my 2wire 2701hgv-e (firmwire v5.xx) as a router to work with my newly setup SBV5121 cable modem. Used the instructions outlined my MarineX but hit error :-
ERROR
The hardware address entry can only use hexadecimal digits (0-9, A-F, a-f) and it must also be a unicast address.
My config screen also has an additional section at the top which is not seen on the screen dumps by MarineX.
DSL and ATM Settings
DSL Line Selection: Line 1 (inner pair)
ATM Circuit Identifier: VPI: VCI:
ATM Encapsulation: Bridged LLC Bridged VC-Mux Routed LLC Routed VC-Mux
ATM PVC Search: Enabled Disabled
What settings should I enter?
Appreciate your help.
liangtam
No need what. Reset the router first, under config in broadband link non mdc page, select direct ip. Done.
mRSlow
downgrade?
only through malifax.
Hi bro sorry for disturbing u , i using starhub modem . . i wan to use 2wire modem at my wireless router , but it was v6 so i flash it to qwest firmware . . but i dont know how to do the setting for it . . able to help me ?
zipper168
Sorry to dig out this old thread...
Any expert please advise how to make my 2701HGV-E (FW ver 6.xx) to act simply as an AP for my star hub sbv5121 (for multiple PCs/HPs).
thx in advance.
HoGnix
thx in advance.
Flash to Qwest Firmware and configure it as a Broadband Router.
devilhell
Anyone configure using V6 firmware? I've tried and it worked but the setting reset after i reboot everything. Anyone know how to keep those setting including the wireless setting?
