will do for me.ok la..not so bad.
As long as the cover doesn't drop off too easily or something I will be happy with it.![]()
but still.. a little disappointed
will do for me.
but still.. a little disappointed![]()
can i juz find out, what is the advantage of is stork android? thks
is e screen responsive?
samsung has a v bad reputation (my opinion huh, dun bash me huh) for non responsive interface/screen ...
pretty keen on getting this model ...
so ppl, pls pls PSYCHO ME!!!! haha
And non-pure Android cannot?Pure Android os is nice to use. U customize ur own interface.
mmm.. u probably tested their older range models like the Samsung Jet era? i would say at that era, i wouldn't recommend anyone using their touchscreen devices but they've since had better quality responsiveness..
although i would still say in my opinion, nobody beats the hell out of iPhone/iPads in terms on screen responsiveness. Apple still had the edge in that.. but only by a small margin..
maybe u shld get ur hands on one to try hands on before deciding.. that's the best 'review' you'll get.. from yourself
Hi all,
Just a quick question... because I searched a little and it seems there are conflicting reports.
Does the Nexus S have an internal GPS antenna? Or does it only rely on A-GPS?
You can't have AGPS without an internal GPS. AGPS is more like a subset of GPS.Hi all,
Both have dedicated GPUs. But Nexus S is running stock Android so it will be smoother.Thanks! Deciding between this and the incredible s. haha. It has a dedicated GPU, so technically the Nexus S will be smoother than the Incredible S right?
to add on, IS is not fully rooted yetBoth have dedicated GPUs. But Nexus S is running stock Android so it will be smoother.
