tofuguy
- Jun 27, 2004
any guys here use cetaphil?
Their cleanser are very mild, but i like their moisturizers for the body.
Anybody can knows where to get recommendation for what product to use for my scar ?
This message is sent from HWZ forums iPhone app
anyone knows where can i get men lipbalm? my lips are cracked and dry.
Does this really works?? i think i wanna buy medium size one.. but very skeptical leh.
get only if u have mild pimples... i cant comment much on severe acne because i dont have .
if u can wait, my friend who has more serious pimples than mine will be posting up her blog review soon.
then you can read her review & decide... there'll be photos of before n after too.
Products containing retinol can help to lighten scars.
My current regime is Bebeco AC-T line cleanser, Neutrogena pore refining toner and Neutrogena moisture for combination skin. The toner contains glycolic acid and salicylic acid, so promoting skin renewal. This is the best combination of products to stop acne. I have been fighting acne for many years but now my skin is clear with this combination. I think it's impt to get a cleanser to remove dirt thoroughly and skin doesnt feel tight afterwards. Toner with salicylic acid is gd to prevent acne. I can see that the acne scar area peeling after a few days hence evening out the skin tone. Moisturiser is for making sure the skin is not too dry because salicylic acid can be drying. Previously, I was using the full set of Bebeco AC-T line but the toner, moisturiser and controller are all too oily for my skin, so I replaced them. The only gd thing abt Bebeco Ac-T line is the cleanser but I think I can replace that also when it's done. Just my 2 cents for those who are fighting acne also =)
where do you get your bebeco products?
do you all recommend buying 'as you need' or try to stick to one brand?
for example, if i am looking to start using a toner, e.g. Kiehl's, do you
1. get the toner only
2. get a whole cleaner, moisturise and toner set?
btw is Kiehl's good?
