The Spectacles Thread.
MBoI1986
this is nice...damage?
Hmm, order in from overseas is around $300.
All my frames have been from Kwong Shin since 1988. Reasonable price - subjective. You can get cheap price but very poor service.
I see. Thanks for the info :)
Sorry I don't know much abt this, but if i will to buy frame from somewhere, can I go up to another optical shop to make the lens of my own frame?
MBoI1986
USD? can PM me where you order it from? thanks
in SGD. just pm ecosales. he doing mass order for oakley i think. I just dunno how to decide for the size, scare order wrongly. And I dunno where can fit in the lens for this model
kisskiss
I have made my glasses with Crizal hi-index w/ my favorite plastic frame! So happy!! Now I can wear them if I'm lazy w/ contact lens! BTW, the coating is like a bit blue-ish... not those usually green.
the card look cheapo (paper, not plastic).
TQeeeee....
eq2addict
ur card different from mine.... urgh... u got free cloth / cleaning kit ? for mine.. cant see any color with the coating. total clear...
kisskiss
crizal cloth = yes. Is that the kit you referring to? I bought my from Malaysia. I heard AR coat sure got color when tile side way. That shop i bought quite big est in malaysia.
oakhub
then how do we know if the shop is providing us the correct brand of lens?
Yup. That is what I have also been thinking. If you pay a premium price for a lens and get one with normal lens, it's hard to tell them apart unless you are in the industry.
KoChi
yea i was wondering that too!. just made my spec using hoya lens.. doesnt come with card
jtch74
Just checking how long will it takes the transition lens to change color when in the sun? My Hoya transition lens still quite clear when standing in the sun for a few mins. But the shop when she put the spec into a uv cabinet for like 10mins n the lens become tinted...is this normal?
This message is sent from HWZ forums iPhone app
eq2addict
wahh.. i go google , crizal suppose to give the cloth and i dun have!! :( my lens dun really have a "tint" but the reflection from florescent light is green !!!
tonite i go bang table LOL
depends on the UV ... more UV more "dark" but i heard SG dun have so much UV compare to AUS/US so not really worth as it wont go dark even though its sunny/bright outside.
stylux
any1 knows how much roughly is the range for rayban spectacle & any place for a reasonable pricing so i wont kena chop carrot...
