Google Nexus S
StanII
i tio chop carrot neh.. i bought my screen protector at singlet shop cost $28 :( but nvm la.. i hope can find the casing asap...
Brand of it? I hope it's not some common screen guard, does your top and bottom have bubbles due to the curved screen?
Ehh my gps with 3g like damn lag. As in it is not real time moving. Anyone encountered this issues also?
haven tried this yet. so can't comment.
ChickenRiceCrews
Anyone tried nexus s gps alr? My like show wrong location and doesn't move as car moves. It will only jump like after 30s. Is it a gps common problem?
StanII
Just flashed my phone manually to 2.3.4
Will test it out later.
StanII
unlock bootloader liao. installing cmw
okay. note that after flashing to 2.3.4 and rooting it, your cwm won't be perm until your rename the file install-recovery.sh to install-recovery.sh.bak using a file manager with root rights.
HMAN
if you just want to root..you dont need to unlock bootloader.
@ 2.3.3..use this gingerbreak app..this will root version 2.3.3 ..
After rooting..install ROM Manager
From rom manager..reflash recovery..reboot into recovery...manual applying 2.3.4 update.zip ..mount system then apply super.zip.
StanII
I just placed my phone beside my friend's galaxy s and his samoled pawned my slcd upside now. Sigh.
StanII
Anyway guys, do you observe that the back battery cover of this phone scratches damn easily. Refering to thoae hairline scratches. Use spec cloth wipe also scratch. Zzz
And what cases to recommend for local nexus s i9023 sets?
StanII
Hmm guys does the H logo show up at times on ur phones or only between G and 3G?
My network mode is now UTMS, can be checked via *#*#4636#*#*
What's ur's?
