Please log in and verify your age to view this post. Why?
hi jetpack,
what is custom and stock rom?
My side is playing around with an android TV box (with google browser, youtube, internet radio, etc) sort of like smart tv but not so smart yet lolx.... there is firmware button for update which we frequently get from a taiwan manufacturer then i happen to get another firware from a china factory website and install and it works..
it this the kind stock rom or custom rom that you mean?
hi jetpack,
too late, my 2 samples of china pad juz in about 8.30pm ago.
you are right about the china android market, seems like even if i manually key in the market address, it does not allow me to install at all. This is bad but there is something that impress me, this baby can watch movie online like those media players which are selling hot and it support usb 3g dongle E1750 but i have not test as the dongle is in office. it can play youtube without problem but the flash player is evaluation copy. I will ask from factory if they can provide the rom that allow to download from google market.
My another sample works like a champ becoz they use standard rom i guess
How about Singapore Dollars $139 Android 2.2 China Pad?
To get that price, we must at least order 20pcs.
If my side can hit 100pcs per order, I think $99 should not be problem too (no promise)
My side will do all the dirty work behind to ensure they reach singapore without damage.
Express your interest pple in here and i keep u all guys updated...
interested in this if the price is good.
This is good info. Thanks for sharing.
Think will skip China pad then.![]()
Good news ! 4GB storage mystery solved.
Factory engineer reverted with the following:
1. In normal windows system, if we format at 4GB sd card or thumbdrive, we usually left with about 3.75gb with fat32.In android, it follows the same theory
With my understanding for windows, I assume the following
Internal Memory (C:\) 2350mb
Data storage (D:\) 938.66mb
RAM DDR2 512mb
Total 3800.66mb
Jetpack, do correct me if my assumption is wrong.
At first i do not believe what they say and I open up the casing and I found 4pcs of k4t1g164qf-bce7 samsung nand flash
then i google it and found pdf from samsung telling us how to tell the density, http://www.samsung.com/global/business/semiconductor/products/dram/downloads/ddr2_product_guide_apr_10.pdf
Factory also admitted that the battery level at their end also stops at 88%..and they checking with processor cum main board market if this can be solved.
Then i go google android market and found "battery calibration" tools but dam i do not have root permission (in windows means administrator right)
For more info can refer to here https://market.android.com/details?id=com.nema.batterycalibration&feature=search_result
