Eczema
  • Need someone to talk to?
SpeedingBullet
No pdts ever helped mine, so i've given up lol. It doesn't get worse anyway, it stays at the usual spots. (for years)
billovee
Use 茶叶 mix with hot water to clean up that part. It works. Or even can bath. Direction by god in my dream.
It may sound abit crazy. But it is true as i also got this problem.
Try it. As 茶叶 is very cheap. But must use quite awhile and then your problem will be gone.
CaboWabo
i have heard of similar methods, tea tree oil to be exact many says it works
vr-user
dont let it get worst thn the red flares man if not it will spread even more... at least that's for me...
anyway if the flare is really bad i think you can go to the doctors to get a jab, the last time during my bmt my arms flare up until dam red, got a jab from my camp's mo and the flare when off withing the day it was quite good... but not sure what was the jab called
yes pls get a jab asap.
control it before it gets out of control.
2 jabs at once for me. It works perfectly, a few days later the flare up gone liao. :D
Impz82
Wow, I didn't know there are people here discussing about eczema.
I have been suffering from it since 2 years ago. My throat area and underside of my legs are much darker. Seems to be triggered from heat. If I am kept cool, it actually recovers but the recent weather is causing it to come back because I will scratch when it itches. (causing darker and flaky skin). Thank god that I am wearing business clothing most of the time, so it cannot be seen at all.
Currently, I use QV wash which is very gentle on my skin. Will Cetaphil be just as good, cos it seems slightly cheaper.
vr-user
i used both before,but like not much difference :s22:
the darker areas i think will lighten up, but need wait very long :(
Sofero
moi hubby also gotch, very xin ku for him i see riao damn sad.
he using QV also, but weather too zai he sweat alot and all the patches come out again.
kimage
Eczema is a tough skin condition that affect physically and emotionally.
I have super mild eczema around my neck area during my childhood days after that its gone. But 3 years ago, my eczema condition blown and flare up around my face, neck and hands area. It was quite bad that i can't go to work nor face my friends. People around you will be asking how happen, why your face so red and dry etc.
As usual consulted the skin centre and a few private clinics that are known to "cure" nor "keep your condition under control". Tried all sorts of treatment, eg. pills ( cyclo, penidsone, azatronprine, light treatment, creams ). As far as i could say, this medication will damage your skin and health in the long term. Eventually i gave up on western medicine.
For those who are suffering a big patch of eczema, be it on your face, neck, shoulder. try TCM treatment rather then kept taking all those pills. For me it helps alot especially after acupuncture, its less itch and gets better.
For those using QV moisturizer, you can complement it with coconut oil when applied on your body. For the face, you could also add some coconut oil mixed with it and apply it on your face.
For bath, can try olive bath oil complement with raw salt and mixed with it
Feyfey
i used to have it...then they went away after i stayed in US for a bit. Think it's the climate.
Recent months they came back. Probably due to stress. First it appeared on the right leg...then now came out on the left le. gg :sad:
CaboWabo
huai come back to sillypore :(
billovee
Trust me...the above method work.
I think im only gifted in that kind of ability. Other stuffs im sucks at. :(
Sometime this kind of ability not good also...sometime know the future of something. :(
papa_hippo
does anyone know if eczema = feng mo?
Last time primary school I kenna so called 'feng mo'
and gone after going doctor for injection.
however, yrs later now people mentioned i got eczema and it is not getting any better these days...
i could not even sleep well...
I am currently using QV Soap Bar... seems like not really good...
I took medicine too but also cant cure it
