H&F Program Compilation
pekipom
ops my bad.
so would it be great if i just do the main 4 SLs and not other isolations? for now?
hey the program is pretty simple. just start light and increase 2.5kg per exercise every workout. at the starting you probably will have enough strength left after the whole routine so you can throw in isolations if you want. just make sure you don't compromise the main exercises
at the later stage, probably won't be able to do even if you want:s22:
kaixax555
ya i think later will be sho tired can forget about isolation le :(
crandfs
OIC, thanks for enlightening. I'm gonna try it starting tomorrow.
Wathen
hey TS, i was wondering if i could still follow your ss guide in the first post if i had trained too much chest and little back muscles in the past?
That is to say my chest is bigger than my back muscles because i stupidly didnt train my back muscles in the past
sashaBEAR
Can the SLs be considered full body workout?
Would it be better if i follow the SLs instead of my current splits?
rundymc
It's full body (obviously, lol). It's the definition of full body.
If you're progressing on your routine, stick with it. The most important thing is trying to push more weight more times week in and outl
sazuro
As long as you're still progressing on SS (lifts are increasing), I would suggest sticking to it. Just focus on getting your lifts up, and your back will grow. Rows/Deadlifts/Pullups are your best friends. And of course, EAT.
Don't fix something if it isn't broken.
HOWEVER, if your lifts have stalled then it might be another scenario.
Your current split is the one on page 1 of your thread right?
If its just to get bigger and stronger, the mirror and your lifts are a good judgment.
As long as you seem to look bigger, and your lifts are progressing, you're obviously doing something right.
As bear said in the other thread, doing a sh*t routine with heavy intensity is far more effective than doing a prescribed routine with a lack of intensity.
sashaBEAR
Ah, okay.
Got you but week in week out means?
sashaBEAR
Ok thanks :)
Haha sounds fine then
Wathen
I want to ask if it is okay to run or use HIIT on rest days to build up my stamina for my napfa test? I hope to run 2.4km under 12mins
galapogos
Moderator
Moderator
Yes.
Getting under 12min is frankly not very hard unless you're extremely obese or 80 years old.
Wathen
Yes.
Thank you for answering! i want to ask about warm downs as well, after doing the basic SS, do you guys warm down by running for 5 mins or stretching or just walk out of the gym?
galapogos
Moderator
Moderator
Actually you can just add the HIIT after your strength training.
sashaBEAR
How does thrusters sound after your SLs? Think its gonna be so draining
