The Spectacles Thread.
honcho
Anyone wore this before? Does the temple (the thin titanium portion) break or distort easily?
ctl_img.aspx
I am wearing the reflex 71xx, but the side (near the TH logo) does corrode.
So choosing between the TH spring, and other TH with the non-rubber temple.
jonleelk
ctl_img.aspx
I am wearing this currently, all black model. So far ok, but I'm a person who is quite careful with my specs.
honcho
Oh.. I am quite rough with my specs. :D
Can I know if the thin portion is titanium? Is it flexible?
Are the screws loose too? (Which results in the lens shifting a little..)
san333
Yes, the thin portion is titanium and flexible.
I just bought it 1 month ago.
x3dnd3x
Anyone knows where to hoot / make aviator sunglasses ? I've been looking for red lenses aviators for quite sometime already . Hooted those cheap ones from Amazon and BKK but they don't seem to last .
Looking for something like what Pitbull is wearing in this MV . Sadly , Rayban doesn't sell them . :(
DaRkXiDe
An alternative would be get a Rayban aviator and change the lens to a red one. Of course then lens won't be from Rayban.
x3dnd3x
Meaning to say i hoot the cheapest Rayban aviator and change the lens at a spectacle shop ? :s11:
DaRkXiDe
yeah, but you gotta check with them first weather they have the red you are looking for. I checked with my colleague like don't have.
Passionate87
thegardens3b
x3dnd3x
Like that still worth it to just hoot the frames frm Rayban meh ? Might as well get it straight from normal spectacle shop ? :s11:
SnowBloweR
Hi all,
I got quoted for a new wayfarer black at SGD160
clear plastic lens from Crizal at SGD176 for eye degree at 700 each side with one side a slight agsthematism.
Good deal?
DaRkXiDe
If you can find the sunglass you want off the shelves then of course not worth it to buy ray ban hahaha.
Hi all,
Good deal?
The frame is cheap. But any ideas which index of lens they are giving you?
thegardens3b
Hi all,
Good deal?
Super good deal, high chance that either frame is off 2nd quality or lenses are of lower range.
unclebutcher
Hi all, I'm relocating overseas soon and need a new pair of specs(use my current pair as backup). Was wondering what brand I could get for about $200-$250. I want those nondescript, full metal frames(or frameless also can), that are pretty hardy.
maybe something like this:
My last two spectacles were bought at Thomson Plaza, both were by this brand "Police" and are pretty hardy (at least the first one was), the second one, the paint flaked off from the frame...sigh.
Wondering what brands I could get for that price range. I dont need fancy lenses, just the normal kind will do. Also, which shops would give me a good deal?
Thanks in advance!
