Post your Android screen!
floodgate
Yes, succumb to temptation & go get it now. :s13::s13::s13: :s12::s12::s12:
succumbed and now regret that i didnt do enough research....
cant get rid of the sensation lock screen so it shows up after the widgetlocker lockscreen.
so i have to swipe my screen many times
1. unlock on widget locker
2. unlock on sense
3. draw security pattern
will try out the sensation temp root and see if can enable widgetlocker's auto-swipe.
kEvinErd
2. unlock on sense
Have you tried downloading No Lock or sth like that from the Android market to stop the sense lockscreen from appearing? Might work..... And as for the security pattern, you can always choose to off it. haha
antidoxy
heres mine..my 1st android phone :D
floodgate
tried no lock. not really solution for me since i want to use the security pattern. no lock will bypass the security pattern too.
will try out temp root see how much of a hassle it is.
widgetlocker has option for lockscreen auto-swipe for rooted phones.
Rui2
i still cant perform any screen shot. anybody is kind enuf to be shi fu? :)
kEvinErd
Oh.. Didn't know that.. So the No Lock app bypasses the stock lock + security pattern lock, but not widgetlocker? Cool.. It truly does what it's meant to do. Haha
ltylty
dang.. got to root. :s13:
thanks!
Another way is to get those battery apps from the market, which will shows an additional battery icon with % on the left side of the status bar, but is if you are fine with 2 battery icons in the status bar.
