(Storage) SSD Discussion Thread
fantasyrulz
OS master, slave for data.
Btw why you still using IDE?
AHCI is better for SSDs:o
just figured that out....
im just a average kid who knows bit and pieces bah sad :(
just set everthing to achi already
my biggest problem now is that my programs in my hdd dosent quite
work the way they should..
anyway ssd is real fast i must say.. boot up in 15 seconds using bootracer to check.. to logon is 9 second
RazerDA
Now this is creepy.:eek:
You got any power failures?
If not, something is really wrong with Intel SSDs
nope, my comp just hang suddenly, and after rebooting, thats it!
damm it...8mb bug..goodness, anyone can help where to RMA ? can top up change to 510 series anot haha
Just Me
OMG... to think I almost bought the 320 series.. Sudden death without cause? :s22:
superman888
I am still having a P45 motherboard, with the OCZ Vertex 2 120GB currently below $300, is it a good purchase?
Or, I should spend more on Vertex 3 or other brand?
doughdough
Lately, I've been hearing that almost all of the SF-controlled SSD's are experiencing various issues (BSODs, freezing, 8mb bug etc etc). I'm guessing that's pretty much most of the SATA III SSD's ? Need some opinions in this, as I have an ASUS G53Sw and looking to buy an SSD before the end of the month :x
Thanks in advance!
Mach3.2
Btw you how old?:o
You try call to ask the intel rep lor.
btw 510 is use SLC flash right?
Firmware problem, SSDs dun die out of a sudden, unless the flash die.
fantasyrulz
i think its wise to go for sata 2 then 3...
wait for it to mature before going into it will be a wiser choice
currently im at sata3 sandy bridge..
fast is fast but after my windows update, i cant even boot my system
there is just too much things going on in sata3
fantasyrulz
i got this case whenever i wanna do my first bootup,
i always have to unplug a plug again my ssd sata to start my com :s22:
wth
xtreme84
The Intel 510 is MLC I believe. SLC would cost too much. And now I've got a good mind to get the Intel 510 instead since it's the only SSD that's relatively problem-free. Or at least I haven't heard any issues about it.
Mach3.2
is the firmware out?
Intel haven make noise about firmwares yet:s12:
Yea, hope they solve the problem before i got enough money to buy one of the ssds, if not need to get 510(more expensive):(
And btw, why 510 more expensive?
fantasyrulz
sorry to bother u guys again..
just flashed my bios to a more stable edition
and disable all those sleep, turn off hdd options
now im thinking is there any software or things i can do do test the stability of my ssd ?
fantasyrulz
if im not wrong 510 supports sata3 just like for ocz vertex 2 to vertex 3
Mach3.2
Oh.. So better controller..
My laptop run on sata2 anyway:s22:
