Realtek Mod X-Fi Driver
jyyj87
i've downloaded the file from the 1st page of the thread.. but when i installed the audio driver, it says 2.62 in the installer instead of 2.65... is that correct?
ov2rey
yes it will install 2.65
sorry i will fix the error on next update
fatboy
Sorry more noob questions from me. After installation, I could not run all those creative settings (no creative card detected) BUT I could enable THX from the creative control panel and enable all the settings inside there.
So just enable all and this is deemed working? Not really sure if I could hear any differences from my speakers :s13:
ov2rey
could u post a SS?
ArcticCheetah
Can use this on XP :look:
No. Microsoft changed Driver Architecture from Windows Xp to Vista(That was why there was so many complains on Vista Sucks but it is not really true) so not it will not work.
Btw Windows Xp sucks.
No.
You have to go into safe mode (hit F8 rapidly during booting) to activate the Software. The login account has to be administrator.
Read the README.
No Creative Card Detected = Fail.
Make sure your Audio Device is Realtek.
JackWulff
i`ve maybe got a problem with the TruStudio.
this is what SB Panel says
SB X-Fi MB2 (Realtek High Defintition Audio)
this is what TruStudio said, if i tried to select a device
(no device found)
the SW-Lock files
CTD1JXF23A
CTD3SPO23G
CTD5H2W3DK
CTL42SW23M
CTL52C6FE2
CTLD2JX234
CTLD14KLI5
CTLE2C3BA1
CTLP22SV21
CTT78HSK12
CTT92KD23N
i still can do all settings on Control Panel, Console Launcher and TruStudio.
Hardware
Realtek 892 on AsRock 970Extreme4, OS is Win7 x64.
I did the activation in Windows and save mode.
So this is correct that i can do all settings, but TruStudio dont find a device?
ov2rey
(no device found)
the SW-Lock files
CTD1JXF23A
CTD3SPO23G
CTD5H2W3DK
CTL42SW23M
CTL52C6FE2
CTLD2JX234
CTLD14KLI5
CTLE2C3BA1
CTLP22SV21
CTT78HSK12
CTT92KD23N
Hardware
dude did u try enter safe mode replace all this file?
JackWulff
yeah. And all settings also work in Console Launcher - it makes a difference when i change something. So i think its totally normal that TruStudio did not find a device?! I dont know what TruStudio should do better as Console Launcher.
ArcticCheetah
I don't think TruStudio is working what is confirmed working is SoundBlaster Panel detects the correct device.
