IBM ThinkPad Users' Group
nicholasii
I just received my X220 yesterday which i ordered through lenovo US on 31/8.
Used comgateway too.Check with you,what was the billing address you entered?
A friend of mine had his T420 rejected like you too,we were guessing its due to the billing address.He had input his Singapore address as his billing address while i entered my comgateway address as my billing address.
Maybe you try again but this time use the comgateway address as the billing address.
Like sian sian to buy le :(
dao
I was wondering if the Thinkpad Power Manager is really good or not? I am now using on battery power almost everyday. Everyday will perform a full recharge. I wonder will my battery wear out very fast?
Thinkapd power manager is really good. Just most people do not know that it can configure not to charge every time you connect to power. I set it to charge only if my battery is below 35% and stop charge at 96%.
sWirL84
Azrielsc
i think one issue with msata is that it supports until SATA2 speeds only. But if you have the msata slot unused, I will highly recommend getting a msata ssd so that you can get the best of both worlds (Speed - SSD, and storage space - HDD).
:D
Yup, that's my train of thought as well! :)
Ibodnano
how do i import lenovo netbook from usa lenovo site to singapore? vpost? and what is the solution if i dont want my netbook to be sent to my home address(because it is a rented room)? thanks, it is urgent.
sWirL84
Flying to HK!
Thursday, September 15, 2011 Location Time
6 Departed Facility in CINCINNATI HUB - USA CINCINNATI HUB, OH - USA 05:11
Really fly around the world siah...
Trip 1: SHANGHAI, CHINA -> ANCHORAGE, AK, USA -> LOUISVILLE, KY, USA -> SALT LAKE CITY, UT, USA -> PORTLAND, OR, USA
Trip 2: PORTLAND, OR, USA -> CINCINNATI HUB, OH -> HONG KONG -> SINGAPORE
sWirL84
I use CGW and seems ok. Not sure about the rest like VPost or BL.
Need some luck to a certain extent I feel, quite a few have hinted how to do it.
Once it reaches CGW or whatever, you can send it to anywhere...your office address also can. At that stage, nothing to do with Lenovo liao.
Ibodnano
can i tell them CGW i want to pick up my netbook at their office?
dante-z
i cant answer your question, but can you answer mine ?
Which netbook you ordered ? issit bvery cheap ?
thanks.
