Thank you for the info...I am probably asking too much question when I have not even recieve the nook yet..
Is the installation steps of the MIUI v2 the same as CM7? I googled this and some sites says that it needs to install thru ROM manager which I am not sure what is this.
yes. you can install the MIUI thru CWM same as CM7. just dump the zip file and install from there and your are good to go. and also remember to wipe the eMMC and cache before installing.
if you want to overclock, you can use the latest darlingri for CM7 and get nook tweaks from market.
If you find the resolution too big, get LCD denisty and change it back to 180 or 200 for better viewing purpose.
Reviews on the whole for MIUI v2 is that its pretty, very pretty and its quite stable and responsive after overclocking. THE MOST IMPT is that it has good battery life, and can sleep.
The only bad part is that you have to reply on soft buttons, back to good'ol days button saviour, which isnt a big problem for me. ( i enjoy the fullscreen luxury of the NC)
milyrad.
