The Hair Thread - Part 1
BYYYBYYY
Hello, can recommend me if i wan a soft touch to wax my hair? (must hold it in place)
iPodMcCoy
anywhere with huge range of sebastian and schwarkopf products except salon? looking for new clay and hairspray, any to recommend? prefer extreme matte look. thanks :s13:
Limpeishicrone
i see schwarkopf products in watsons, but those are the consumer range. for salon schwarkopf products.. you either order from them directly online or salons :crazy:
hard to find a hairspray that provides an extreme matte look and holds good in singapore's weather. as for clay, all(?) of them are matte.. too many to list :s13:
iPodMcCoy
heard that some beauty shop at chinatown do carry them?
Chong Yu Fu
anyone knows is there any product like hairspray or wax can style up soft- texture hair? Because not matter how i style, it still drop down.. , or should i buy a better shampoo?
MookieTea
Get a shampoo that is for your hair texture. What wax are you using now? Usually, hairspray after using wax is recommended for good hold.:)
Litmuss
got a osis+ hairspray and sebastian hairspray at chinatown! osis+ is quite cheap there, how much did you get yours at? strength lvl 3 300ml one right?
Which part of Chinatown can get osis+ hairspray.
