Mens Facial Thread...
geraldlee93
Anyone knows if there's any product which is able to lighten acne scars?? :(
Just recovered from acne outbreak and my whole face is filled with red spots...
stylux
i used to have red spots , blemishes , i go to raffles hosptial for chemical peel , ard 100 + per treatment , for me first time , i can c very good results , blemish like all gone.. but thats for my case..
Limpeishicrone
no side effects?
sacrifar2
anybody can recommend a good dermatologist?been having a bad acne outbreak since for a past few months
darren89
where can i find places that does laser treatmwent at a affordable price? Previously i did was $300 per session.
i would like to cured my deep scars recover from acne. :)
MookieTea
Any know any cleanser or facial product for dry skin? Face is really dry, causing it to be oily i guess?:(
Alex Kwa
anyone know of any product which is good to remove blackheads?
All products you apply are aimed to reduce the obviousness of blackheads. If you are talking about pore packs, these will expose your pores to more dirt and dust, and the black heads will come back.
If you are looking for a permanent solution, you should see a dermatologist.
darren89
anyone can share more about chemical peeling? quite interested
i done it before, topical acids of different % (depending on how serious your condition is) is applied.
It improves skin texture and skin colour and repairs sun damage by stimulating new skin formation from underneath.
need a few treatment to see the improvement,
IMO, for light scars still okay, if deep scars perhaps laser is a better option.
Vadher
the acne.org bp regime seems to work for me. its important that you avoid touching your face, even when you use face wash and apply lotion, should be done in light circular motion
buttersstotch
Agree that not touching your face is very important. Our hands and fingers are very dirty and contain millions of germs. Everytime when I wash my face or apply creams/ moisturizer I will wash my hands with soap thoroughly first.
Another thing is try to at least use basics. Facial wash -> toner -> moisturizer -> sunblock If it's day time. Don't be lazy, this really helps.
Limpeishicrone
hi where did you do it at? my skin condition's pretty mild just with some blemishes and scars. want it to be completely clear though. doing it once should be ok i think.
any side effects? and did it work very well for your skin condition?
kukucheow
i'm a 19 yo male. i feel like trying out bb cream. what does it do to your face actually?
Noctix
looking for products to treat these,
- dark eye rings/eye bags,
- acne scars/reddish spots (not so severe but few spots around)
- oily skin (usually does at the end of the day...)
- moisturizer
any recommendations?
buttersstotch
Dark eye bags, use laneige eye cream. Moisturizers use biotherm homme. Acne scars use whitening products. Best if u use biotherm homme whitening range cleanser, toner and moisturizer. Oily face no choice la just blot at the end of the day
