it was $360 during COMEX period when I called haha
btw can this monitor used on ps3?
Why don't you try calling ?will it still be $389 if i were to call?
Yes, via HDMI -> DP or HDMI -> DVI cable. Audio passthrough is pointless since the U2412M doesnt have built-in speakers.
To get audio you will need to use the composite cables.
thx for ur response
Its a good business decision. Probably less demand for wide gamut 24" monitor now that the U2711 is so much cheaper now.
If a pro was buying a monitor for professional use, the pro would go for U2711 not the U24xx.
If the U2412 has the same image quality as the U2311 it'll be fine for most users.
If somebody is buying you a monitor, you get to pick either Dell U2412M or Samsung S23A950D.
Which one would you pick?
Hi, can any owner of this monitor measure the height of the stand please, tyvm![]()
$319 for this Dell UltraSharp U2412M 24" LED-Backlit LCD Monitor.is it a good price?
Should i get it or not?
share pls
