twister @ tampines 1, kason. can only think of him for east sideAnyone have any reputable hairstylist to recommend in the east? Nid some help here. Thanks
dont understand your question.. you mean you seen hairstylists that only do the styling, no cutting/consultation?Thanks for recommending! Will try out soon. Cuz my current hairstylist left the scene le. ): anyway, Kason can advice, cut and style or only style?
Korean dunnose wor...
but
another jippun site for Women ish this.
http://www.rasysa.com/pkg/style/all/new/
i beo-ing naos
why thick cannot leave it long? my hair's thick and i have it pretty long..Just asking, my hair is thick, hence my hair stylist told me that i cannot leave it long. Then my hair ish also very dry sue to my cca, last few years always in the sun.
So are there any treatment or haircuts that you guys could recommend ?
a picture of your hair will help, hard to visualize.. and anything's possible, just depends on how you style it.Hi my hair belong to those fine and smooth kind... however was thinking of like cutting really short and u know do those spiky one... will it be possible?
you can try soft rebonding, alternatively, flat iron straightening should help. how come yours isnt helping? what brand of straightener are you using? 'foam' isnt really neededFrom young, my hair has been a little curly. Just a tad bit of curl(bowl like shape). Any ideas on how to keep it straight throughout the day? I've tried straightening iron countless of times, the effect stays there only for about 1-2 hours. Do I need to apply some kind of foam before doing the straightening?
i have no idea whats ice rebonding(probably a marketing thing), but soft rebonding will make your hair look more 'natural straight' instead of poker straight from the normal rebondingWad is the difference between soft rebonding, ice rebonding and e most common kind of rebonding?
Anybody tried sebestian craft clay? Easy to wash off? Strong hold or not?
