Cheapest Android Tablet option
furyoo
Finally took the plunge and order a Novo 7 for myself. I was holding back till I saw that there was an actual forum for it on Slatedroid. Means good things will happen for it.
pat7471
Shipped out liao, cannot track yet:(
i just got an email my order shipped :D:D:D
Mine still "processing"... 那也按呢?
If tomolo still not shipped, then my wife, father, mother, dog, hamster birthdays all patterns come out liao...
seasonscrystal
I'd just update it to 1.7.2 firmware. all seems well, comes with Market & Music player:D All seems well, need to test more.
But the problem that some apps not shown in Market still there, it's due to Market registering it as Novo7Advanced. So skype, whatsapp, go keyboard, etc will not appear. You'll need to find apk installer:s8:
seasonscrystal
Ya, it's said a few Herotab custom rom maker also bought Novo7A. It'll be interesting :s12:
Bishamonten
for all novo 7 advanced bros
Merimobiles
Did not have time to give it a full try but this is the updated version of the Ainol NOVO 7 with updated Market: http://www.megaupload.com/?d=UXTL195V
me still waiting for mine :( but just recieved an email say my order confirmed liao ^^
Bishamonten
btw when i get mine should i updated to 1.6t first or can directly update to 1.72?
Azure
kyleongwl
wow...juz rcv mine..v thrill.
on the apps market,, below method don't work?
HowTo Fix market cache problem, not all apps (like Google's) can be found:
1. Open the Market and press the home button to return
2. Go to Settings \ Applications \ Manage \ Running
3. Press "Market"
4. Press "Clear cache" (do not clear data)
5. Press "Force stop"
6. Return to "Settings \ Applications \ Manage \ Running"
7. Press "Google Services Framework"
8. Press "Clear Data"
9. Press "Force Stop"
10. Start Google Market, it must give an error
11. Reboot, once back Market should work, if it gives an error it could need another minute to work
12. Test the access, search Skype on the market, it should return 400+ results including the original Skype and google's apps like maps / streetview / docs and skype
kyleongwl
Those bro/sis who want touse Daiso screen protector, the size to cut is 18.5 x 11cm. But it's really very soft, don't stick well:(
Just ordered from gmarket A500 clear screen protector, then cut into size:D
maybe try a galaxy tab instead?
Ainol Novo 7 = 146 x 95 x 13mm
Galaxy tab = 190.1 x 120.5 x 12 mm
* Not too sure if Novo 7 stated size is the screen??
seasonscrystal
I measure liao. it's 18.5 x 11cm for the whole glass/plastic area. Actually if can cut 18.3 x 10.8cm it'll be great;)
I'm getting A500 cos I needed an extra screen protector, so order together:s13:
kyleongwl
Hmmm...tat means all the Galaxy tab case & SP shd b ok for this unit.
Will test with my friends tmr.
