(Storage) SSD Discussion Thread
runforyourlife
Moderator
Moderator
Let's put it this way.. technically, the way they work is totally different.
To the mainboard/CPU, it is just a storage device and makes no difference to them (some H/W or OS may apply optimised settings for SSD or HDD thou, like defrag etc..). or, in very over simplified term, the CPU doesn't know whether it is SSD or HDD, to them, it is a storage device. period.
That means if I can survive within 120gb, I can simply install an ssd and make use of ext hdds, yea?
kkh83
Selling CruciAL M4 256GB $650 srp 688 SMS me 92996458 point collect will be at fuwell thankx you
FP1990
upgrade my Macbook pro 15 inch 2010 hdd to ocz vertex 2 240gb
Looking to upgrade my Macbook pro 15 inch 2010 hdd to ocz vertex 2 240gb. Read some of the post online, but it seems like some of them nvr have problem but some full of problem. Can anyone give me some advice? and how is the performance? Where can i get a cheap one too?
tech_oasis
Just wondering is there any 'preperation' needed when loading os to SSD as boot drive? procedure exactly the same if it was harddisk?
Thanks
xtreme84
Thanks
Set to AHCI mode in BIOS before doing your Windows 7 installation. Turn off disk defrag after you finish installing Windows.
roberttty10
Hi,
I am using the OCZ Synapse Cache 128 GB SSD.
I encountered the following message when trying to install the "Dataplex" programme:
"No qualified SSD cache detected"
Has anyone encounter this before?
Thanks!
yukita
if i use sandforce 2 based ssd on sata 2 port, what is the limitation like?
any source of the benchmark?
Luffy Pirate King
What happen if i never set to ACHI mode and simply install my OS to my SSD and set it as boot drive?
Luffy Pirate King
Btw, any helpful bros can help me out? What to do next after installing my OS into the ssd? Any tweaks or settings? I disable defrag liao after reading the previous replies. Whats next? :D
