hi thanks for help. i tried to convert all my files using convertz, but some files still display non-readable words. Is there any manual way to rename it using unicode format?
1st, is it a mp3? If it's m4a or wma, sometimes those files are notoriously hard to edit their id3 or equivalent tags.
Personally I use a combo of 3 apps, convertz/MediaMonkey/foobar2000 to do tags. All are free.
Convertz to convert to unicode.
MediaMonkey to totally clear out id3v1 tags, you just need id3v2 tags around can liao. Same app to manually edit tags if need be.
Foobar to do the checking....if those same files display properly their tags in Foobar, most of the time it will appear fine on phone.
Yeah, tagging of audio files in Android is a b*tch....
