~WindzStriker~
- Jul 6, 2007
i like Osis. never heard of Matrix. where to buy from?
a shop in chinatown. you shld know le ba
hahaha
Osis is the next brand i tried too after Loreal. Osis is ok
but i like Matrix more, it is better den Osis.
but i wana see if go other better den OSIS
guys, hair falling, any solutions?
I'm guessing you're talking about thisQuestion, not sure if you guys still remember a website which was posted here quite some time back? Its a local website regarding hair, has pics of different hairstyles and also has a forum for hair discussion s well.
Anyone still remember the URL?
http://www.thehairthread.com/
I think it's pretty much dead already.
agreed!!!!!!!!!!I'm guessing you're talking about this
Can describe more for osis and matrix? Like in wat ways its better all these...
TIA!
pull fringe with wax, spray in burstsAnother question: sometimes i wax my fringe to the side, top it off with spray. But after long, it will fall back into a state like theres no wax/spray. But if i do too much, its as though my hair kena salt water damn thick and hard type(ugly). So how do ppl, make their fringe stay yet look natural? Please help. Thanks.
Wax: renati paste
Spray: loreal strong hold
hi guys any conditioner to recommend for ppl with dry hair?
well i would like to think that it doesn't stay, its cause you used too much wax.. then the hair becomes heavy, and also clumpy =) maybe you can try to use less wax and more spray.Another question: sometimes i wax my fringe to the side, top it off with spray. But after long, it will fall back into a state like theres no wax/spray. But if i do too much, its as though my hair kena salt water damn thick and hard type(ugly). So how do ppl, make their fringe stay yet look natural? Please help. Thanks.
Wax: renati paste
i just use a tiny amount of wax.. i dun spray my hair nowadays.
