Galaxy Note Accessories
Akai Ryu
at ebay
V
victorlht88
Guest
wow damn cheap, where u go find huh? even the SGN users i saw there mostly naked leh
Same area in shamshuipo, got apliu street, golden computer centre all those places lo.
There are some poorly designed flip cases though which rely on tape against the battery, crappy designs.
Akai Ryu
similar to the fenice case pics above?
V
victorlht88
Guest
Not sure. But the local ones here can't be used with the original battery cover. So u gotta remove the battery cover and rely on tape between the phone battery and flip cover. Quite retarded since all the dust will get stuck.
darknez
Use the tape provided. Then superglue the other flat surfaces. Finally use silicone to seal in the gaps. :D
