[][][] Google Galaxy Nexus [][][] Thread
bundy
saw galaxy nexus at the telcom shop at bencoolen, quote me $9XX, its an export set from Hong Kong... Have Hong Kong launch the phone ?
Fifa03fan
XWKK9 out in MoDaCo
I don't recall any news saying it's out in the HK market.
evodog
Thanks for the recommendation, how's the fit around the edges? My cheapo ones didn't stick to the curved edges.
sorry shud hv mentioned, its enroute so i can tell you when it arrives.
my last steinheil for my htc was top notch IIRC
miyamiya
IIRC, the steinheil sgp oloephobic screen protector doesn't cover to the edges. It leaves quite a gap actually. The sgp flex screen covers up to the edge but it's a wet application type so it has those orange peel texture.
I'm using a cheapo screen protector that came with my sunny wave case. It covers nearly to the edges so I'm fine with it... just that it attracts fingerprints and oils like a sponge... sigh..
Fifa03fan
Thanks, I think I will stick to mine as well and wait for more reviews
nofate
read ard.. seem GN hav issue wif MTP being use in XP?? alot comment saying to use on win7..
anybody facing such issue?
miyamiya
Yes me. Actually it's for my work computer which is on win XP. So now it's just for charging my phone, not transferring files..
Luckily it works ok on my win 7 machine at home.
agcken12
for those who using custom rom... check which rom are you using??
Fifa03fan
Custom kernels having some battery issue in standby. The AOKP rom has some nice tweaks but also has issues with Market purchases.
If you want to try a custom rom, MCR with stock kernel is quite good.
Sauron
Saw GN in Korea, very tempted to buy. Anyone knows if I can use it in Singapore?
miyamiya
I'm currently using Android Revolution HD. Wanted to try MCR but didn't want the rotation of launcher. Do you know if this feature can be toggled or is permanent in the rom?
Fifa03fan
It's available as an optional add-on in his (paid) kitchen. I'm not sure if the pre-baked version includes it.
Or you can try MCR but use Nova Launcher, which looks almost the same as the stock launcher, but with a "forced portrait" option.
Btw, a 4.0.2 version of MCR is coming soon.
miyamiya
Ah the prebaked one is probably the rotating launcher. I dislike modaco because it's overpriced for a forum. I actually paid once without realizing that the subscription is actually only one year. And its a waste of money because I only used the custom kitchen a couple of times only.
