Proposal Ring - Part 2
rediffuse
How is Destinee or Brilliant Rose branded?
Isn't branded the likes of Cartier, bvlgari or Tiffany & Co?
joseph_hiroyuki
thanks jhchoo85, yup so that's why i thought and decided that getting a local jeweller to set would be better.
i'm thinking of those "rectangular" emerald cut rather than those "square" cut.
any advice on what would be good selection of EM cut?
if you going for emerald cut can try JannPaul, i think the price kinda cheap?
[GorgeouS]
Kimmjio
fkm1180
Got my ring!
Yippie!!!
Got my ring from JP last night!!! make the final payment...
Now waiting for the day to come...
Only concern now is the ring size whether can fit or not... pray!!!
naxchua
Yippie!!!
Good Luck!
Carnage
Definitely this.
Do you know branded jewellers only used 57 facets diamonds? They do not use modified cut.
Carnage
Read the few posts on branded vs. private jeweller.
My 2 cents: for retail brands you're paying for their trademark and their physical presence. For private jewellers, there is always the danger they may close shop over night and leave you with zero after-sales service.
final1
Cartier, Bvlgari and Tiffany are jewelry companies. They make jewelry.
They do not go around digging for diamonds.
An example of a company that supply diamonds to the jewelry companies is De Beers.
i.e. Jewelry company is not the same thing as diamond company. Though that is not to say that De Beers doesnt make its own jewelry. They have a shop at MBS i think.
delson_tan
In techie terms, Asus and MSI used to provide motherboards to Branded PCs, now they are selling their own too. :s13:
linusz
How much should the budget be for a
0.45 G VS2 signature hearts and arrow piece?
