BYYYBYYY
- Sep 20, 2011
stop thinning it then
Sometimes its natural not purposely thin de la
anyone tried Korean kind of perm for guys hair?
Yupp, my hair is same as yours... Soft and thin.. After using wax, MUST use spray de. Use ur wax sparingly, if not the gaps will e thr and look very clammy and wet.
pls, when u grow ur hair out it will be thick. it cant be 'naturally' thin unless ur at that stage of life then i bo wei gongSometimes its natural not purposely thin de la
there's also no way wax can make your hair look wet unless ur using blue gatsby 'wax'
Hmmm, thanks for the info but cuz no matter how i leave my fringe, its very thin in tt sense i cant make those compact fringe type. Any idea? ):
Your hair wouldnt be thick if you just let it grow long. You got to tell the hairstylist, you want to keep thick, they will cut it short and thick, and thus when it grow out, it'll be thick and long. The kind of fringe you want.
But when it's short, quite ugly, so no choice, got to endure.
Is Hair sense a good salon to tryout a new hairstyle fr JC kid? I kinda feel like changing a hairstyle (Probably cant change much since its short -.-!) But yeh. And i dont really have any hairstyle in mind.
going to my one in lucky...
Hmms okay thanks! Will give it a try before school reopens haha.
Any hairstyles to recommend? My hair is relatively smooth, but thick. And my sides are really short.
Calling all experts! That time you all say century square which hair stylist is good again??
How about something like that?
Woah, this needs styling man!! The wavy layered part is kinda hard to master
Anyway, guys, is there any ways to make one's hair more rough?
