ONT -> Dlink N5402SP -> Plug1 -> Plug2 -> PC.
Aztech 115EP
nice, I suppose you are on the 100Mbps plan?
If I use 110E will there be more signal loss than 115E ? cos the former is theoratically rated up to 200mbps
sorry for the noob qn =P
if you read up what MarineX have performed in 1 of his threads...
he clearly states that 200Mbps will never hit 200Mbps...
110E is a crap device. At tops it can only provides you a good 60-70Mb/s and this is it.
yes, im on 100Mbps plan.
no offense, but if you decided to go ahead and believe on your wallet than the survey conducted by him, don't complain.
cheers and good luck on your purchase.
Perhaps you might have left out the fact that I'm only on the 50mbps plan, hence I was wondering if it will make a big difference. Thanks for your advice nonetheless !
This is crazy! I juz installed my 100Mbps optic fibre today n below is my results less than 1m away! Rooms total no or drop signals!
Pls advise me wat to do! Tks alot...
Never state what equipment you use, never state what setup you have how in the world is anyone going to help you? :/
* sorry I dumb dumb de...
Starhub gave me Dlink DVG N5402SP...What other info u all need? Pls pardon me for my ignorant...
Sorry, I forgot to state...tks alot for willing to help...
I using DLink DVG N5402SP
Huawei HG 863
btw... is that an iPAD?
can you use a proper pc to test it instead?
Yup, I use iPad n iPhone. Sorry I abit suaku. How to use proper PC to test? Where to download the app?
I also wonder y my rooms got almost no reception...haizzzz
Tks alot for helping
Is it just me on the iPhone 4, as far as wifi throughout is concerned, that channels 5 to 8 yield the best performance where downlink > uplink.
If I may elaborate, the speedtest defaulted with News Media Express will yield uplink rather consistently at 20 Mbps. Channels 5 to 8 will typically achieve 25 Mbps downlink, hence downlink > uplink. Other channels above/below 5 to 8 will yield equal downlink performance or lower and also throughput performance penalty is much more sensitive to distance once out of the channels 5 to 8.
Test is performed on 20m bandwidth. I've noticed poorer performance on both 40m bandwidths. Router is the Dlink N5402SP. WPA2 AES. B/G/N.
The problem is not make noise or wat but then...it's definitely worst than my 50mbps board band before...Now cannt surf net in the rooms n I am only staying in 5rm flat...
I will test on my computer 2moro cos now no access to it.
Anyway, I will read up more 2nite. I am a noob when it comes to IT stuff.
