StarHub MaxInfinity Fiber Optic - Experience
Frontiers
ONT -> Dlink N5402SP -> Plug1 -> Plug2 -> PC.
Aztech 115EP
UpperCut
Aztech 115EP
nice, I suppose you are on the 100Mbps plan?
If I use 110E will there be more signal loss than 115E ? cos the former is theoratically rated up to 200mbps
sorry for the noob qn =P
Frontiers
if you read up what MarineX have performed in 1 of his threads...
he clearly states that 200Mbps will never hit 200Mbps...
110E is a crap device. At tops it can only provides you a good 60-70Mb/s and this is it.
yes, im on 100Mbps plan.
no offense, but if you decided to go ahead and believe on your wallet than the survey conducted by him, don't complain. :)
cheers and good luck on your purchase.
UpperCut
Perhaps you might have left out the fact that I'm only on the 50mbps plan, hence I was wondering if it will make a big difference. Thanks for your advice nonetheless !
Frontiers
110ep(a) then.
"110e is a crap device" as you might have left out the fact that i stated that as well =p
dreamybutterfly
This is crazy! I juz installed my 100Mbps optic fibre today n below is my results less than 1m away! Rooms total no or drop signals!
Pls advise me wat to do! Tks alot...
* sorry I dumb dumb de...
Starhub gave me Dlink DVG N5402SP...What other info u all need? Pls pardon me for my ignorant...
Qubicfactor
Never state what equipment you use, never state what setup you have how in the world is anyone going to help you? :/
Frontiers
btw... is that an iPAD?
can you use a proper pc to test it instead?
dreamybutterfly
Yup, I use iPad n iPhone. Sorry I abit suaku. How to use proper PC to test? Where to download the app?
I also wonder y my rooms got almost no reception...haizzzz
Tks alot for helping
Frontiers
Speedtest.net - The Global Broadband Speed Test
is ridiculous to make "noise" just by using a mere incapable unit to test your speed.
rooms no reception? can be the device issue or router settings not configured correctly.
Frontiers
ask yourself this:
Are you on WPA2 + AES?
Are you on 802.11n?
Transmit Power on 100%?
Channel <= 11?
if you have no idea what i am talking about, try learning a thing or 2 from the guide before jumping conclusions~
Dlink N5402SP Manual
banana55
Is it just me on the iPhone 4, as far as wifi throughout is concerned, that channels 5 to 8 yield the best performance where downlink > uplink.
If I may elaborate, the speedtest defaulted with News Media Express will yield uplink rather consistently at 20 Mbps. Channels 5 to 8 will typically achieve 25 Mbps downlink, hence downlink > uplink. Other channels above/below 5 to 8 will yield equal downlink performance or lower and also throughput performance penalty is much more sensitive to distance once out of the channels 5 to 8.
Test is performed on 20m bandwidth. I've noticed poorer performance on both 40m bandwidths. Router is the Dlink N5402SP. WPA2 AES. B/G/N.
Frontiers
1. you.
2. it shouldn't be as 40 bandwidth provides a better overall in my case.
and theoretically, 40m should provide a better overall. your case with iPhone is probably the limitations of an overpriced handset and dumb contract t&C
dreamybutterfly
The problem is not make noise or wat but then...it's definitely worst than my 50mbps board band before...Now cannt surf net in the rooms n I am only staying in 5rm flat...
I will test on my computer 2moro cos now no access to it.
Anyway, I will read up more 2nite. I am a noob when it comes to IT stuff.
Frontiers
is broadband btw.
if you place your router in 1 corner of the flat, don't expect too much out of it... since i have no idea on your home infrastructure is not a good idea telling me it is "just" a 5room flat.
best to provide us with the layout of your home coupled it with your router placement and etc settings
ZhuTou!
Dun understand why people use phone to test fiber speed
Are u going to use phone to download large file?
Most of the time is using it to surf net only
Maybe once in awhile download games/apps thats all
