Ask Yamaha / FAQ
YamahaSG
Featured Sponsor for Home Theatre & Audiophiles
hi Yamaha, YHT-S401 looks good, but i'm looking for a bluray player cum soundbar. Is there any such products from yamaha?
Hi Silkworm,
Sorry for the late reply.
Yamaha doesn't have any products for Front Surround Systems category that comes with built-in players.
Let us know if you would consider one without built-in players.
Cheers!
YamahaSG
Is the YHT-S401 already released? I went to Courts at Causeway Point, the rep says SG still not available and was surprised to see it retailing at $999. Thought I read it's $699 or something. Btw how much is the 401 retailing for? Thanks.
Hi!
S401 has released in Best Denki / selected Courts & Harvey Norman stores.
YHT-S401 - Suggested Retail Price : $1049
Visit our latest Yamaha Music Hub in Best Denki - Vivocity / IMM to audition both YAS-101 and YHT-S401.
Cheers!
YamahaSG
Hi I've been looking at the Yamaha soundbar either the yht-s400 or ysp-2200. I have a Samsung LED smart Tv (not so smart IMO but never mind). I've been watching movies and am frustrated that during the dialogue the volume is soft so I turn it up. Then the super hero appears and suddenly I have to scramble for the remote to turn it down because of the booming bass [I currently use the Bose Companion 5 as my system].
Question is: with the Yamaha soundbar will I be able to hear the conversations and not scramble for the remote when there is sudden explosion in the movie?
Another question: what's the most compelling reason for me to get the ysp-2200 instead of the yht-s400?
Final question: what's are the RRP for the YSP-2200 and YHTS400? And where can I get them?
Ok, really final question: any CNY promotions?
Thank you!!
Hi!
I think below feature will help you in this.
UniVolume
This feature maintains a consistent volume level between
different channels, programmes, commercials and
input sources. It can be switched on and off.
UniVolume is available on YSP-2200.
But very sad to say, our shipment will be available only after Chinese New Year [Probably during that week of CNY].
You may consider to have a audition of YSP-2200 if you can bring up your budget.
Cheers!
Charlie_Zhang
just bought the YHT-S401 , im a noob in audio system....
if i do not want to use my tv speaker (LG LW6500), i will just need to connect a hdmi cable from my tv hdmi arc point to the hdmi connectors on the subwoofer right?
My hdmi cables are arc type. Had set the hdmi settings on receiver to "on" as well
but i can seems to get any sound from it
YamahaSG
Hi Charlie,
Thank you for your purchase.
All your sources [Set-Top Box from Starhub / Singtel, BD Player, Game Consoles, etc] should use HDMI if available to connect to the YHT-S401 subwoofer first. Then only use the S401 HDMI Output to TV with ARC indicated.
From here, you have to check the TV Settings how to turn on the ARC function. Some are auto, some are not. I am not too sure from TV. Maybe you could check with LG.
Cheers!
quektg
Go to your TV input list and in SIMPLINK to on/off the TV speaker or HT speaker.
Charlie_Zhang
Hi Charlie,
Cheers!
Thanks for the reply. Had to set my lg arc function manually to "on". Haha, enjoying the sound bar now
astroboy82
Hi, Just wanna ask where can i purchased YHT-S401 , Have tried going to Harvey Norman and the salesperson was saying that yamaha singapore have stop bringing in YHT-S401 as this product is discontinued by yamaha. Is it true? Thanks.
YamahaSG
Hi Astroboy,
Not true. Please visit Best Denki make your purchase.
Cheers!
Justbear
Sorry ah, can I ask a noob ques? I connect my av hdmi out to tv (1 of tr hdmi ports) with v1.4 hdmi cable. But no sound coming out from tv. Did I short connect any cables? TIA
pico43
Questions on Yamaha MCR-840
Hi guys,
I am looking at the yamaha mcr-840 to replace my ageing mini hi fi in my room. I am no audiophile but I would like to have a reasonably good sound system. My room is not soundproofed, and the system will be placed on a wooden TV cabinet.
Just like to ask for opinions on this model. Does it offer good sound quality? I listen to mainly new age, classical and vocals.
Also, should I get a higher grade speaker cable to replace the default one that comes with the unit? Will this significantly improve the sound quality?
Thanks for any inputs!
YamahaSG
Hi bro,
I trust your setup was : Source -> HDMI -> AVR -> HDMI -> TV
Right?
In your query of why "No sound coming out from TV", because the Audio was channel into AVR instead of TV.
If you wish to turn AVR into "Standby" mode and use the TV to playback Video & Audio, then go to Menu, HDMI Settings, Turn "ON" the HDMI Pass-Thru mode.
Let me know if i could further assist you.
Happy new year in advance!
Cheers! :)
YamahaSG
I have a DSP-AX1, but it hasn't been turned on for quite some time. I got it working after plugging it into the socket for an hour, then it worked for 2 hours. I switched it back to 'Standby' mode, then it wouldn't turn back on already!
What's the problem??
Hi bro,
Sorry, i replied you in your PM before i saw this.
Cheers!
Justbear
Hi bro,
Right?
Cheers! :)
Thanks. How about I want to output my tv sound to amp? Same setup. Tv hdmi av in <-> avr hdmi out
YamahaSG
Hi!
There are 2 ways you can do it.
Using HDMI is one of the solution. Ensure your connections are AVR -> HDMI -> TV[ARC] Input.
Enable your ARC, some TV is auto. For this, check with your TV Manufacturer.
Another conventional way is to use Digital Audio Output or Analog [Red & White] Output to the AVR.
Cheers!
YamahaSG
One last ques. Does htr-3063 hdmi has arc?
Hi Justbear,
Nope. HTR-3063 does not have ARC function. Only HTR-3064 onwards will have ARC function.
Happy new year bro!
Cheers!:)
