[][][] Google Galaxy Nexus [][][] Thread
Gixxerfied
Just flash to this radio..Nt sure if it's an improvement now since reception is usually gd at home, only gets sucky when i'm at work..
colin27
Yeah you are right about the troubleshooting thingi.. These cases are always almost impossible to replicate! Anyway, since I removed the lightflow app, havent had another shutdown.. Although its a bit early to say, but I sincerely hope its fine! :D
I will get the screen protector hopefully today or tomorrow.. I saw someone selling the Rock-hard case which comes with the screen protector as well for 22 bucks.. just that I am not so much into buying cases, but if its cheap and good, then why not! :D anyone else using that case?
http://forums.hardwarezone.com.sg/m...rful-naked-shell-hd-screen-guard-3523664.html
I used it and fit is great. However if you intend to use the extended batt, I'd suggest you don't get it. The sp that comes with it is low quality imo and it peels at the edges.
alprakas
Thanks Man! I just got one case. I was looking for a screen protector, but the guy didnt have one, instead he showed me this case for 10 bucks.. I liked it and bought it! Haha
SUNNY SAVERS SAMSUNG GALAXY NEXUS I9250 BLACK 'S' WAVE: Amazon.co.uk: Electronics
Then my friend got me one screen protector as well .. I think for 8 bucks or so.. yeah I know, its cheap, but does the job.. and in any case, I am pretty careful with the phone, so should be all right! Plus this case has a raised bit on the front, so the screen doesnt touch the surface when put face down.. so that is that..
The phone seems to be working fine now, but the battery life is sucking big time.. Last night I went to bed with 100% charge, morning it was down to 40 %.. Hahaha I am sure, some app is messing up with the data.. but too lazy to hunt it down for now! :D And I am happy!
colin27
Bro, go get the extended batt with back cover. I'm happy with the extended batt (2000mAh) performance. Can last me throughout the day with moderate use on browsing net, syncing, sms. :D
agcken12
search ebay singapore... got mine at $6..
Gixxerfied
So far on the xxkk6 baseband, reception is very gd..H even in underground moving train..battery life seems better..
kennyboy
Local is one gsm900/1800 which is the same as euro baseband? Which is also the same for xxkk6 which is why nt very gd for USA as their frequency is slightly different..
And I wonder if this xxkl1 is better..hahaha
I really hope nobody from US flash modems for GN on their US models. :D
devilcm3
how much you get ah? and from where ? :eek:
Gixxerfied
but still sucks >.<
this sucker if constant 3G for 3 hours sure dead :s13:
For me quite normal usage enough to last me 1 day..gf 15mins on my phone drain off 20% already.. Maybe later flash this baseband to try..
Edit: Just flash to XXKL1 baseband..Charging hp now after a long day..Report back tomorrow.. :D
devilcm3
wah if 3G is 3 hr then those in the the States using LTE then how? 1.5 hrs only?
yeah , mine is 3 hrs only ... anybody report higher? :p
actually LTE version got boosted battery so theirs might be 2 hrs +-
Gixxerfied
From about 1030am till just now 11.40pm..Whatsapp, some browsing, youtube, fb etc etc..
Gixxerfied
So far on XXKL1 baseband, 12h 30mins with light usage, wifi connection and HSDPA.. 78% remaining..
Gixxerfied
18h 27min with 62% remaining..Light usage..Abit FB then Whatsapp..On wireless and HSDPA..
Seems like this baseband is here to stay.. :D
