HP TouchPad
picagen
all the patch are for 3.0.4, once you update to 3.0.5, the patches won't work. And in the updated preware for 3.0.5, there is no patch available yet.
silentscope
hi all... I have just received my touchpad. Can anybody point me the way to load my touchpad with android? What's the latest version and if it is recommended to switch?
much thanks
radiancez567
much thanks
you can watch youtube videos, just go search for hp touchpad android
one such is How to install CM7 (CyanogenMod 7) Android on HP Touchpad - YouTube
recommend you watch more than one video first before attempting if you are totally beginner, and read the stuff mentioned in the video...
it's dual boot so you can choose to boot android or webos during startup
silentscope
Hi all,
i have flashed my TP to android CM7 Alpha 3.5.
The only problem i have now is Wifi having the bug problem when it went to sleep mode. it cant connect after i make it wake up and have to manually re-enter the password again for it to work.
anybody have workaround for this issue? please share
Thanks!
radiancez567
Hi all,
Thanks!
also had problem with the wifi and i used Wifi Fixer & FXR Wifi fix from Android market to hopefully 'solve' it. now not as frequent problem.
yhw22
By the way, can we still port over to Android after updating WebOS to 3.0.5?
Or vice versa.
Igene
I just installed for my coll with CM9 GAPPS. Just completed so haven't really tested. And he took away the pad after installed. :s13:
Igene
OK. I've finally loaded mine with ICS Alpha 0.
I downloaded a GAPPS file from HERE, got a new MBOOT (0.3.5) and use back the old CWM Tenderloin 1012. Rename (name it update-*****.zip)and put all files into cminstall folder and run the Novacom cammnd. Wala... Everything works great so far (includes Market).
First encounter with ICS :D
silentscope
damn irritated.. cm7 alpha 3.5 can connect wifi but after sleep no wifi..
upgraded to CM9 ICS, cannot even connect to wifi.. but webos can connect..
kns.. anybody can help me?
Igene
My WiFi connection problem gone after ICS upgrade. 3.5 always have WiFi problem then have to disable and re-enable. No random reboot too. It's been almost a day.
grynove
find in the market wifi fixer. clear cache and dalvik.
anabolic
it's out now. still buggy tough.
Touchpad FTW! I loved my Touchpad, Gingerbread was buttery smooth and had great battery life.
In the end, I sold off my Touchpad because of the lack of 3G, not being "always on" was a bother and frankly not how a tablet should be.
I have since migrated to a Lenovo K1, which is mighty impressive, aside from the Touchpad's IPS screen which is definitely one notch ahead.
Rock on Touchpad Users, the only tablet with triple boot!
ocillator
This $99 touchpad is really the bang for the buck now that it runs ICS on it..
I just received the official sleeve and it feels brand new all over again with triple boot - WebOS, Android 4 and Linux
