Realtek Mod X-Fi Driver
Overmaxx
in creative console is avalable only entertement mode. is correct? where are game mode?
bugmenot45
Hi everyone, sorry for my bad English :)
I need a x-fi mb mod for Realtek_XFi_MB_R222_Fix (Windows XP version).
Megaupload is gone .. so i can't find any working link :look:. Thanks for the help!
ov2rey
i wont release any Xp version anymore, other way is to upgrade your system to 7
bugmenot45
I know it but my pc is too weak to run windows 7. It's great if someone can give me link of old x-fi mb mod support windows xp.
halocast
this one can replace the default drivers?
will work for creative xtreme music sound card with ultimate windows 7 64bits?
ov2rey
please read on the first page: only support Realtek audio chip
this driver won't work on Creative Xtreme sound card
parrot1553
hey,I just bought new speakers Logitech Z506,they sound amazing already^^ but since my motherboard is a bit old (ALC883 soundcard) I tried ur software,but i dont like the changes in sound with all of the control panels,crystalizers,thx's ,dolby and other crap ^^.I find it really annoying that i have to switch game/music/video every few minutes,cuz im spontanious guy ^^,also stereo music already runs in 5.1 without the creative thing,maybe because of speaker fill...So my question is,is the sound quality better,just by the main realtek driver(without creative software)? A few years ago,I had an x-fi mod driver again was version 2.16 i think,it was just the main driver,and it really improved quality,i even tested it and i gained about 5db signal-to-noise ratio i think.
ov2rey
if you don't like so many option, you can always use v1 driver.. it's standard without any addition "Game/Music/Movie" option
parrot1553
Should I only do step 1 of the "readme" inside? only run asussetup and reboot?
This is on the version 1 driver
ov2rey
yes, if you have creative driver installed..
downgrade from v2 to v1 just need to click on asus setup only.
you don't need to reinstall creative driver.
parrot1553
did everything and now there isnt game/movie/music like u said,but i still have the creative control panel and x-fi crystalizer and cmss-3d were enabled by default,i disabled both of them since i like the sound better,not using the creative control panel at all,was it really necessary to install? would the sound quality be different with and without it(just do step 1)
snorge
If you wish just totally ignore the creative stuff. I run the modded driver without it and everything works fine (with the exception of DTS) which I removed from the driver files myself because for some reason it causes problems on the 888 chipset. The creative software also bogs down your pc my games run considerably faster without.
parrot1553
okay,well its all running fine,i just watched a blueray movie and sound is fine(same like before) maybe i just expected too much :) always wanted to make it sound like in a cinema,when they shot a cannon my legs to tremble :D but i guess its impossible in home conditions,I tried increasing bass very high,+15gain also in the media player added true bass,but still when they shot the cannon the sound isn't boom,its...crystal clear xD
azncookiecutter
So I can't get CMSS-3D working, any tips on how to get it to work? Tried all 3 drivers, no luck. Gigabyte GA-890GPA-U3H with Realtek ALC892. EAX and Crystalizer works fine.
graymalkin
@ov2rey
When are you going to get THX TruStudio Pro to function?
Even with the latest Version of his mod it still has no function and still says "no supported audio-device detected" when you click on "select audio device" in the drop down menu.
So why even have this function in the mod if it does not work?!
You can try and see for yourself! Changing the settings and turning the features in THX TruStudio Pro on and off does not do anything. Also try changing the audio device in the drop down menu.
IT DOES NOT WORK !!!
