Galaxy Note Accessories
Akai Ryu
waitforyou
actually i do a fair bit of doodling too :D
itching and thinking of getting this folio, phone compartment meant for fruit phone, but guess i may well just stuff it in the zipper compartment or just in between
this is from gmarket too? got any link? Thanks.
darknez
Been using it for a month already. The Zenus Prestige series using genuine leather and mine had few scratched already cos of the glossy leather surface. Among all my leather cases, this one takes the cake! Looks very elegant and classy.
Moisturize it! That should minimize the scratch on the leather.
I know this is not a new product, but I just got around to buy it.
awanone
ultra thin cover recommendation
Hi I am looking for an ultra thin cover for Note, my problem is that i have original dock and car kit for NOTE . i also bought a plastic cover for note as shown in the picture
and when the cover is on the note it wont slide into the desktop dock as shown in the image
notice that the note wont fit into the dock , i am looking for recommendation for some cover which i don't need to take out when using the dock/car kit thanks
Akai Ryu
try the ultra thin tpu which some r using here but not sure how much margin the dock allows for "case" or even 1mm thicker back cover like alu or texture
awanone
thanks for such quick reply , any link where i can see/buy "ultra thin TPU ?
Jhyun
Can try searching ebay for "galaxy note ultra thin"
so wat fashion is ur sgn into now? did u got a alu bck cover fr ahem???
anyway im still looking for another tpu that can be use without back cover, so far sgp capsule works perfect...hope the momax wont disappoint
Using a normal S-line TPU, offers plenty of protection but not outstanding in looks..... and still waiting for my phone cordi to arrive from Korea...
Jhyun
So far, all my collicks using this casing. No issue at all. Some of them even order 2 or 3 & it's tight as I feel it.
I don't know what went wrong with yours...............:s8:
Another of my collick even buy the Iphone 4S mercury casing for his wife through me..................;)
Hmmm... might have gotten a bad sample then...
Does your mercury case protrude above the case at the front?
Mine doesn't and I dun want to think how good it will protect the front if it drops face down...
Akai Ryu
Quite alot of those Mic case like ultra thin can be found at "ah Beng" mobile shop already
Jhyun
Yeah, but ah beng shop is usually extremely over-priced...
If you can wait, getting online is usually better.
