Proposal Ring - Part 2
jimlwk
[GPGT]
Finally got my diamond from a private jeweller. Here's the picture. :)
It's 0.63, triple excellent, F colour and VVS2.
Hca score of 1.6 with all excellent except very good spread.
Apologies for the low quality pics cos I took with my iphone 4 camera while viewing thru the lens. But I think it's good enough to see the Hearts and Arrows in it. ^_^
llvisionll
What brand you referring to? High-End Cartier or low-end Taka? haha. For 'his' band, basic without diamond will also need around ~$850 leh. For 'her' band will be around ~$650.
They are known for their quality in their diamonds and also their craftsmanship in customization..
It will depend on what you want to do...
The price of their bands are defintiely cheaper than branded..
Craftsmanship quality is good..
IMO, what's most important is that you get to have a 3d imaging of your design for customisation (especially if your planning to customize)
Carnage
[GPGT]
Finally got my diamond from a private jeweller. It's 0.63, triple excellent, F colour and VVS2.
Looks good.
Mind sharing how much you paid for this?
Carnage
Thanks! Setting not done yet; with setting will be $5,300 max since I wanted a tiff & co channel set design with multiple diamonds at the sides. ;)
That's cheap.
My diamond cost me 7k. Although my color is D and clarity VS2 only.
jimlwk
That's cheap.
Lucky me, I did ask JP to quote me too. They quoted me $7k plus too although it's a super ideal cut diamond. IMO, the difference in price not really worth it for the difference in cutting. :p
My diamond has no H&A certification on its GIA cert and I had a tough time finding this since my jeweller gave me about 15 diamonds to choose from. This one has the best HCA score.
Carnage
Oh then I can't go there already. Some girls insist on GIA cert and all the nonsense.
What's the difference in cutting?
You could share your contact, good for future users.
jimlwk
My private jeweller can help to find various diamonds be it gia, ags or even non cert ones (depending on his contacts' supply).
Mine is gia:2121924041.
Gia cert maximum cutting grade is excellent but other certs may have ideal or super ideal.
Super ideal > ideal > excellent but all these are classified as excellent under gia.
My contact is Mr Au and his place/shop is in euro asia apartments. He is a nice hongkie guy. 94888001 is his contact. ;)
[GorgeouS]
[GPGT]
In the hearts picture, the 11 o'clock heart is small, 7 o'clock heart got small crack.
In the arrows picture 1 and 3 o'clock hearts are abit misaligned.
The triangles (between the arrows) are different shapes and sizes.
Did you see the diamond with the ASET Scope?
The Hearts & Arrows scope only shows the symmetry of the diamond.. it doesn't analyze the light leakages.
Cos even if the hearts & arrows pictures looks good, what it only means is that the diamond is cut symmetrically. But this can also mean that the diamond have symmetrical light leakages... Personally, I find the ASET scope more important that the hearts & arrows scope... cos light leakages = less sparkles.
If I'm not wrong, JP only carries diamonds with HCA score below 1.4... But the HCA tool is just a filtration step cos it doesn't use all the facets in the diamond.
But, if you're willing to compromise on the Cut of the diamond, it would definitely be cheaper... It's quite hard to compare this diamond with JPs...
This is an good video explaining the ASET scope.
jimlwk
Yup, agree can't compare with JP cos different league in terms of cutting. I haven't see my diamond with the ASET Scope since it's not available. Don't think will go to the extent of buying one to assess it too.. haha..
IMHO, I can accept a little imperfections as long as it's value for my budget. Think the more impt thing is the journey to seek for a diamond from the beginning to the end that makes the story behind the ring more meaningful.
final1
Agree, buy what you can afford.
If you can afford perfection go for it.
If you can't afford perfection, cut some corners without compromising quality too much is fine by my book. Agree that the 1 and 3 o'clock arrows in the 2nd picture are not aligned perfectly (i.e. its not a straight line). Does it matter alot? Depends on the person.
yvette
wah... i cannot find the imperfections that you pointed out....
jimlwk
Yup! Although the 1 and 3 o'clock arrows are misaligned, I guess my gf prolly won't notice.. haha heck.. even if it's aligned perfectly and i tell my gf, it prolly be a only "me gusta" kinda thing. :p
llvisionll
Nice analysis, bro! Please consider that it may due to human error, becos limlwk took the photos by iphone. Do note JP took pain to adjust the diamond in almost perfect position before they take the photo.
Afterall, just based on the price and H&A photos, limlwk gt himself a pretty gd deal in my opinion
Carnage
Yes I agree too. Quick glance won't be able to tell the imperfections only until [Gorgeous] pointed it out.
I agree the ASET scope is most important. Really can show the difference in sparkles.
DawnMin
I doubt she will :s12: Unless she starts comparing and stuff like that
cut: actually misalignment is at 3,6,7,11 oclock and centre is slightly misaligned
girdles are uneven some painting some digging
star length is on the short side of 50%
carnage is right, the aset can tell much more
one more factor on price though, is the faint fluorescence :s12: no one saw that
