# Galaxy Nexus # The All Things Root Thread #
Gixxerfied
read that thread already before I posted here, could you check your nexus and see what imei sv you have for comparison?
Imei SV 01
It's to ID the software version so if the rom u flash is of a different SV then u will have different SV isnt it?
I'm on AOKP build 24
shonen45
thanks for the quick reply. but i dun see the market in the drawer n wanna set up the account go to accounts n sync no more gmail alr. seems like all stuff relating to google is gone?
Have you flashed GAPPS? Which custom ROM is installed? If it is AOKP, you can download the GAPPS Feb-12 from their download site.
GAPPS give you back Market, Gmail, and other Google apps.
~WindzStriker~
hmmm from the reviews i read, many ignore flashing gapps.
yup It can be found in the same download page of the AOKP rom, most bottom
lukesky
Hi Guys, can I know how are your GNex battery life? My on screen time can only last about 3 hrs as compare to 2 1/2 hrs on stock 4.0.2. Currently on AOKP B23, Franco Kernel 17.2, only have google contacts sync and whatsapp.
think that's fine. my on screen time is 1.5 hrs and my batt is about 60% so it's almost similar. the screen is the biggest sucker of power so the only way to get more batt life is to get a bigger batt or use your screen less.
Sensational
yea thanks man. i googled n found it alr. now everything's up and running!
Sensational
wah, sounds kinky to me bro.. :s13::s13:
HAHA. ya i kinda forgot. so i went to read it again n just dl then can alr. anw anybody have idea how to sync music from itunes? i noe can just drop into the folder but i kinda lazy to go find music by music frm e file man
secondhandlies
just got nexus. tried to flash aokp build 23, gapps, xxkl baseband and kernel, but always stuck at bootloop. have restore to stock and unlock, root and flash twice but always get the same problem, am i missing anything out?
jeffrey10
I do to have the same problem....I flash ROM and Gapps only....but stuck at bootloop....><
Sauron
I had the same problem until I did a wipe before flashing the rom
