# Galaxy Nexus # The All Things Root Thread #
natapon
You tried checking if it is enabled as an accessibility service? I got the same problems but AOKP's built in one is working reliably for me, so I dont use light flow anymore
light flow is enabled as a service. i used AOKP's milestone 3 build and it worked for a while. Then it stopped working.
Just tried gummy rom too, didnt work.
Fifa03fan
AOKP one doesn't do anything for charging right? as in u can't configure the led to light up during batt charging like how light flow can do?
Cannot. Rather cool with light flow, but then I didn't managed to figure out its inconsistent behaviour
kashix
i'm using light flow.. and my phone sleeps like a baby overnight.. i get like 2-3% batt drop over 6 hrs and my Deep Sleep percentages are in the 80%+
so are u sure it's light flow's fault that yr phone never sleep? could be something else though..
how do you check deep sleep %?
Fifa03fan
Install CPU Spy and it will generate some nice bar graph.
Btw, updated 2nd post with some faqs too.
You all overclock your Nexus to what speed ?
and also the recommended voltages ?
1.4GHz on Jame Bond kernel, but honestly I don't feel any difference. 1.2GHz is sufficient for my normal usage.
numan108
Realised that i did not install the adb drivers properly, though i can see android phone at device manager but with yellow triangles:(
I then tried using pdanet but it take forever at the step install to phone so i aborted it.
I was wondering if it is caused by choosing the wrong bit 32 or 64 for gnex tools. For pdanet, should the phone be in debugging mode?
TIA.
Fifa03fan
TIA.
For me, I uninstalled the drivers and installed the bare drivers.
First time pdanet worked for me even after cancelling the installation. But second time it didn't despite completing the installation :s22:
So who's using CM9 Nightly liao? :D
I was planning to install CM9 once betas are out, but then AOKP came along and I'm stuck ever since :s13:
numan108
@fifa03fan, when u use pdanet, must the phone be in debugging mode?
numan108
Thks for all the advise.
Had problem installing the usb driver for phone using gnex tool.
Then tried pdanet and it always hang at installing to phone. I aborted and was able to see bootload at device mgr.
But i can see any adb device in gnex tool. Think i download samsung driver and then can see the adb device gnex tools & perform step 1 to 6 . Very zzzzz nw, tmr will look for rom, etc to flash. Welcome any recommendation of combo. Goodnight :D
numan108
my pc is unable to read or see my phone via mtp? is there a need for drivers or any workaround method ?
Fifa03fan
Try disabling USB debugging mode. If you on a recent version of windows you shouldn't need drivers for mtp
numan108
I on windows xp pro, i did tried disable usb but still cant work.
When i switch to ptp , pc can detect galaxy nexus !
Sad news is there r quite a handful of people facing this problem from what i gathered from the internet.
If can detect mtp device, then i will put off flashing rom, kernel, etc.
However i did a backup in step2 in gnex tools, where will this file be located & what the name? I want to save a copy to my thumbdrive.
Thks.
QUOTE=Fifa03fan;64395544]Try disabling USB debugging mode. If you on a recent version of windows you shouldn't need drivers for mtp[/QUOTE]
Fifa03fan
Thks.
I had this problem, I forgot exactly the steps but I did remember uninstalling drivers, then starting from scratch with just the drivers and Windows Media Player.
numan108
@fifa03fan, i managed to solved the problem by updating the windows media player to version 11, now can see My computer\Galaxy Nexus\Internal Storage.
Where can i find the backup that i did on Gnex tools.
My stock kernel is 4.0.2, do i need to upgrade to 4.0.3 before flashing custom kernel ?
What's the difference between this backp & nandroid backup as it seems like need to perform nandroid backup before flashing custom.
So many choices of ROM & kernel , me blur liao.
Thks.
Gixxerfied
Thks.
1) Cant help u cos i do nandroid which can be found in CWM folder on ur phone
2) See if the kernel supports 4.0.2..If i nv rem wrongly, Franco supports min 4.0.2
3) The reason why To perform a NANDROID Backup is listed in the steps before flashing the ROM is at least if the flashing screws up or problematic, u can restore ur NANDROID backup
I reco AOKP..Reviews saying Codename Android also not bad..
numan108
@gixxerfied,
I actually wanted to used those that u have listed in post #5 but when i was reading on the franco kernel, it said that it works for 4.0.3 & 4.0.4 and not lower version,
It looks like there are very few custom for 4.0.2 thats why i thought it is better to upgrade the custom to 4.0.3 before find a custom.
Is nandroid backup an app in market that i need to download and run it on my phone ?
Thks again.
Skyy
mtp sux big time.. i try to avoid using it if possible.. use airdroid a lot better
