# Galaxy Nexus # The All Things Root Thread #
pushtopen
I download Franco Kernel Updater from Marketplace($2.39)...Very gd app..Alternatively, you can probably change inside
ROM Control > Performance > Scaling Governor
okay thanks! found it, bought franco's app too! seems pretty useful even without the kernel features
kashix
Any app that can sleep/lock the phone instead of pressing the button? Scared spoilt, sometimes unresponsive :(
davi502
Search the Android market with keywords "screen lock", but not all are compatible with ICS.. Widgetsoid is your best bet, its widgets do more than just locking of screen.
numan108
I updated to the kernel using franco app & it seems to drain my battery, drop from 39 to 9% overnight. Anyone encounter the same problem?
Gixxerfied
Check governor(By default is conservative), cpu scaling(I run at the min of 350mhz and max 1200mhz), hotplug mod..
kashix
doesn't seems to justify running @ 350mhz anymore, 700mhz as minimum in fact allows u to get into deep sleep faster and you risk SOD with 350mhz + hotplug. just my 2 cents worth.
kashix
I'm on the latest kernel updated using franco app, running #18.6, overnight drain from full to me waking up is around 10-11 hours, dropped 5%.
just for comparison, my setting is running max @ 1350 mhz and min @ 700mhz, no hotplug mode. conservative governor.
Fifa03fan
Did you enable the high performance audio option? If so disable it
gink00
hi all!
I just rooted my Gnex. I realised that im unable to sync android market from PC to mobile. Is that because of the root?
currently on AOKP.
numan108
I did not enable the high performance audio option.
I set min CPU to 700Mhz & max to 1200Mhz & disable hotplug mod & weather update and stop unncessary process before sleep and it is ok this morning ( drop about 8%)
Gixxerfied
Nv encounter deep sleep issue(Infact, it seems to head into deep slp probably 3-5mins after i screen lock)..No SOD with 350mhz + hotplug switch on either..
kashix
there is no benefit running @ 350mhz anymore, you might want to revise your settings ;)
from xda
Originally Posted by Mondfahrer
What's the point of using 700 MHz? 350 any disadvantage? I am running 1200 max and 350 min interactive.
Gesendet von meinem Galaxy Nexus mit Tapatalk
I think it was discovered that there was no cost savings (battery/Speed) setting your min at 350MHz. So why not just start at 700MHz
