i will try green soon
blue is cool with white casing
Thinking of modding mine as well
Trying to go ghey and fitting in a plethora of colours if it's 3 different llights in there XD
3 different colors will end up weird
Yes it has better privacy but I usually place my phone away from me, so a wide angle provide a better viewing for me. Maybe I too use to the iPhone haha.just curious, why u need wide viewing angle?
isn't narrower view angle provide better privacy?
thanks bro.
btw, do you have any video converters to recommend that is optimised for watching on XS? Media Go is not able to read and convert video files with .rmvb format.
why not just copy over to phone and play direct? moboplayer can play rmvb files.
Clearer Image of my White XS with Pink Transparent Strip in the Dark
Normal usage is fine when holding in hand. But when watching videos lim peh like to put it down n tilt it at an angle then got abit of problem liao cus cannot see clearly. But biggest issue is still the USB flap, really cui dunno which genius design de, so hard to open n close + the plastic so thin really scare break
true that.. but i was thinking, wont the quality of video not be optimised for XS?
i have been receiving 3 sms'es daily from "Reuters" for the past 2 days...each with a news topic...has anyone else been receiving them??
i'm on singtel btw...
Same. I think you need to call them to cancel it if you don't want. Not sure haven't called them yet. A bit busy with school work these few days.
EDIT: If I'm reading this right, the agreement says REUTERS Asia and REUTERS World is $2 each per month. Sneaky ppl always like to smoke things into the agreement.
the quality will be the same as playing on a computer. reencoding will degrade the video quality further.
The viewing angle issue can be solved easily. And yes, the usb flap. Well, i already prepare for the worse liao.
How to solve the viewing angle?
 move your body lor.
 move your body lor.
Can try avs video converter if u wanna convert to mp4 quite easy to use n fast conversion. Quality also drop abit only.
