The Official Xperia S thread
shikoo
I'm a s2 user and intending to switch to XS soon. How's the batt life compared with s2? I don't know if it's Go launcher that drains more battery. but my s2 dies on me a lot outside.
Here's an accurate benchmark of XS vs S2 according to hardwarezone review
Battery Mileage
Using that same 480 x 800-pixel video, we next ran our standard battery test. The test parameters include having the video looped under the following conditions:
Brightness and volume at 100%
Wi-Fi and Bluetooth connectivity turned on
Constant data streaming through email and Twitter
Sony Xperia S - Start Button - HardwareZone.com
bobbytkc
Battery Mileage
This is very strange. Here, the GS2 lasts about 8 hours playing video, roughly the same as GSM arena's results, but in the GSM arena's benchmark, the Xperia S lasted about 385 mins, not 238 mins.
Anyway, GSM arena has a more comprehensive battery breakdown, as well as comparisons to other smart phones. I'll try to hotlink it:
It seems that the XS has a battery life most comparable to the Galaxy Nexus.
Chevalier
Peiseh for betterbatterystats.. how to see which thing is eating up the battery?? :O
open up the app, there will be two drop down menus. select "since unplugged" and then the other one got 4 options, "partial wake lock, kernel wake lock etc" scroll thru em, see which process has been running the longest.
i suspect its the "alarm manager"
rssd21
Hardware benchmarks - More or less accurate, unless you change clockspeed.
Battery benchmarks - Not so accurate, varies among user habits, apps & contents.
eeLsinneD
Hmm did you guys realize something?
On our redemption coupons it says, "Bring THIS coupon to redeem your FREE pair of Xperia SmartTags."
and since we have 2 coupons, does that mean we get 2 pairs of tags?
XD
Dixon.
XD
i only have 1 coupon le.. :(
enegue84
XD
Eh? You have 2? I only got one in my box! :(
pker88
if u want to service only Sony bishan is the only outlet in sg can help u
others Sony store is just a shop lor
orchard ion Singtel os just a collection cte
best go Bishan for faster service
DigDub
my phone batt life seems good, better than arc s, htc xl and s2. :o
so I find out most headsets with 3 buttons wont be detected by the xperia s.
DoraemonBoi
thanks. I try leaving it till night lor. Hopefully the battery will be fully drain. Right now I plug it into the charger, nothing come out only the notification red light. :vijayadmin:
DoraemonBoi
ok I think is my fault o.o The battery is already flat o.o no wonder cannot turn on. I plug it in into the charger once again for 5 min and it turn on O_O and now the battery is like 1% o.o
anpanbun
False alarm luh. You scare yourself
PongRareRare
Not ur fault, the batt itself is a prob... ( ̄^ ̄)
anpanbun
How do we check what are the apps that are running in the background and how do we disable some apps from auto running at start up? How exactly should we close an app? I noticed when I close an app, it is still running in the background.
