u can try ip cam viewer or tinyCam monitor for android smartphones.
It's true that movement on the iPhone is slow. I doubt subscribing for a higher speed 3G plan can solve the problem if WiFi also produces slow response.
For home surveillance, especially maid abuse, it's always good to have video recording. In case if you're suspicious of maid abuse then record the video as evidence. Even if you happens to see your maid abusing your kid remotely without evidence it's difficult to prosecute her, if necessary. You can record and then playback the video daily at the end of the day or once a week depending on situation.
Nobody has the time to sit in the office the whole day just looking at the PC/iPhone to monitor their maid.
Even when i play back the movie that i recorded in both my QNAP & SYNOLOGY NAS the vstarcam H6837WI movement is also slow & choppy. Ppl should stay away from this cam
Hi everyone,
I'm new to IP cameras and have a few stupid questions...
- IR cams means the led light will be switched on at night?
- which router works best for adsl for 10 cameras?
- can i mix and match different brand cameras and still use the same interface?
- for the user interface, can i set multi level passwords which has viewer access to different cameras?
- are IP cameras as reliable as CCTVs/conventional methods?
Looking to hook up 10 cameras of varying capabilities..
- fixed with zoom or PTZ
- outdoor with IR ie waterproof
All must have direct storage to NAS, SD card recording.
i noticed quite a lot of people use vstarcam - is that significantly more superior than Dlink's IP cameras? i see that some Dlink cameras can be $1K like 5-7x most cameras' prices. Can someone pls enlighten me why the price differential?
Thanks!!!
ANybody can advise if they have encounter audio problems on VStarcam H6837WI? Be it you try to on the "listening" or "mic" function. Have very loud echo sound thus making it unusable at all.
Does the video appear slow and choppy if you watch it live or via an app? How about using wired instead of wireless? What wireless router are you using? What speeds are your camera connecting? If you move your phone/laptop/tablet next to the camera, what speeds are you connecting to the wireless router?
You mean something like SONAR sound while using the MIC? So far, we
have receive reports from some users on this and have reported to the
factory to investigate. None have reported that LISTEN will also trigger sonar
sound.
BTW, which firmware are you using currently?
We have today email out to our clients the newest firmware for the camera.
0.155, which have bug fix on the recording and playback (10x)
Hi Matrix, me using 153 firmware. Will try out 155 today. Yes, listening i got this loud sound. Will try out 155 hope it improves the recording
Hi everyone, understand that this is a thread for wireless IP camera, but I would like to ask if there is any recommendations for wired IP camera ? Usage is to replace baby monitor. Thanks !![]()
I have the same encounter too with vstarcam.
I thot the mic and the cam were too close to each other.
Still the same problem after I moved the mic to the room while keeping the cam in the living.
However, this to me is not a major bug.
Hope that Marix could feedback to the manufacturer to improve the product.
Hi all, anyone knows wheres the reset button for VStarcam H6837WI? Saw online someone mentioned that it is located at the base but i couldnt find it![]()
